battery shortcut on the notification
Hurleygm
354
29
I just figured this out... You can create a short cut in the settings screen by tapping the three little dots adding a "quick setting".
Not what you wanted, but saves some scrolling.
I don't like it because I think the icons are too big.
goin_nil
1,054
13
I actually like having the 9 icon shortcuts at the top of the settings. It makes it quick & easily access my most frequently used settings. (From Note 4)
wei34
