1. li4acdc's Avatar
    I cannot find a setting (or settings) to do the following:
    1) Keep the screen on when on the charger.
    2) Keep the screen on in DriveMode (I'm guessing this could be the same thing)
    Any help will be appreciated.
    Thanks
    02-12-2015 01:25 PM
  2. srkmagnus's Avatar
    Thanks
    I'm not sure that you can keep the screen mode the entire time. However, you can adjust the screen timeout accordingly. If doing this manually is not an option then use an app like Tasker to automate it for you. That way the screen timeout will increase every time the phone is in driving mode.
    02-13-2015 11:02 AM
  3. ajamudc's Avatar
    If you don't mind paying for an app, Car Home Ultra works pretty well and can do what you need. There is a 30 day free trial, so you can test it out.
    Sent from my Galaxy Note Edge
    02-13-2015 01:58 PM
  1. Replies: 3
    Last Post: 02-13-2015, 07:29 PM
  2. Replies: 1
    Last Post: 02-12-2015, 05:17 PM
  3. Lock Screen Notifications
    By mookiekillsit in forum Samsung Galaxy Note 4
    Last Post: 02-12-2015, 03:32 PM
  4. Replies: 1
    Last Post: 02-12-2015, 01:19 PM
  5. Replies: 1
    Last Post: 02-12-2015, 12:56 PM
