02-03-2019 05:36 AM
50 12
tools
  1. Eddie Wingfield's Avatar
    Oh wow! I downloaded the first part of the update. I haven't downloaded the second part of the update yet. I'm not sure if I want to because of all the complaints. I'll wait for a few days to see if there will be any positive comments about it.
    07-09-2015 11:25 AM
  2. Blacklac's Avatar
    The update isn't the issue. It's hardware related. That's why smacking the side of the phone works.
    Unless you have a different issue...
    Eddie Wingfield likes this.
    07-09-2015 11:35 AM
  3. Blacklac's Avatar
    So I hard reset my device, didn't restore any backups, fwiw. Now my camera focus' nearly immediately again. And prior, hitting the side of the device DID work. So it may be more than just a hardware issue, I dunno.
    07-16-2015 10:06 AM
  4. dgreene915's Avatar
    I read somewhere on the forums also that if you give it a decent shake, it wakes it up a bit, i used to have theis problem all the time, now i give it a decent shakes up and down a couple times and it becomes clear instantly
    08-03-2015 10:14 PM
  5. Phil Gallagher's Avatar
    Remove the silver lens cover gently with a knife and see if the camera is still the same. If the picture is clear then the lens cover is your problem. A new one can be purchased very cheaply on ebay.
    08-18-2015 08:07 PM
  6. SHIVA77's Avatar
    I got to say, the rear camera is definitely defective on these units and I am surprised that we aren't making more of a stink about it.
    I have looked at some of my recent pics in full res and it clearly shows that the camera is not focusing right. Most of the times, it's hard to tell, if you are just looking at the image on your phone screen, but blowing it up at full res will show.
    Also, we all know that the camera does not focus at first, you have to shake it, or point it elsewhere to focus and then bring it back to your object, but even after doing that, some of my pics are out of focus.
    Yes, I have removed the little sticker on the lens.
    09-20-2015 04:13 AM
  7. Koda Mcculloch's Avatar
    Somebody told me on the forums to shake the phone when you open the camera app, did that and it fixed the problem
    THAT WORKED, sometimes when I'm on the camera through the camera app or snapchat the screen will like vibrate and then it's blurry. I am thankful for this tip
    09-24-2015 10:18 PM
  8. n1nj4Lo's Avatar
    It's a bug that presents itself in the lollipop update, if you on kitkat and don't update chances are you'll never see the bug or nowhere near as ba, this was discussed all over tmobile forums.
    09-30-2015 10:10 PM
  9. SHIVA77's Avatar
    No, that's wrong. if you look at this thread the issue goes to the first day of release. The problem is with the camera itself and it's not related to the OS version. My camera has had the same problem since I picked it up on the first day of release.
    10-01-2015 04:28 PM
  10. kinjal patel3's Avatar
    Someone told me the rear camera is really good in note 3 n I buyed a new phone as I captured photos of mine all photos were taking blur y so is the note 3 rear camera blur or itz only mine taking blury photos
    11-06-2015 07:06 AM
  11. Armaan Gupta's Avatar
    The camera takes ages to focus hence had to trade it off for a G4
    11-14-2015 08:32 AM
  12. bosslady111111's Avatar
    I have a Lg Metro pcs phone. I turn on the day dream. Go to settings> look for dispaly> day dream off.
    12-11-2015 04:14 AM
  13. OculusFPS's Avatar
    I registered just to say thanks. My camera has had this issue for months and shaking it fixed the issue.
    05-05-2016 09:21 PM
  14. Ain Riz's Avatar
    hey thanks alot, I opened camera and shook the phone the problem is fixed lolllll
    08-05-2016 10:37 AM
  15. Mike Cornett1's Avatar
    This worked for me too. I am guessing the optical focus gets stuck sometimes.
    Me also I shook my Samsung Galaxy s6 and the camera was very clear
    08-22-2016 07:11 AM
  16. Oreoluwa14's Avatar
    Those of you who have received the 5.1 Lollipop update, does that resolve the blurry focus issue?
    At all... my camera is still blurry please help
    01-20-2017 08:17 AM
  17. israelnepo22's Avatar
    add me on fb i found a solution for this camera problem...Israel Nepomuceno...
    01-23-2017 03:18 AM
  18. Richiefierce's Avatar
    add me on fb...i will teach u how to fix that...
    There are a lot of people with the name Israel nepomuceno on Facebook
    01-25-2017 11:23 AM
  19. SHIVA77's Avatar
    SCAM ALERT:
    It's a scam. Only a scammer will try to move you out of a discussion forum to give you "info". if someone has something to contribute they'll do it on here.
    01-26-2017 02:32 PM
  20. Susan Presley's Avatar
    Holy cow, dropping the phone on my desk made it work -- for one picture. I have to drop it each time I want to take a picture.
    02-23-2017 09:46 AM
  21. danellz_violet's Avatar
    really disturbing if phone lens don't work properly. I have had the same issue. Can't fix it out. What should I do now. Can anybody help me?
    My phone is like that. What im going to do
    06-11-2017 09:05 PM
  22. Imamonth's Avatar
    I've had the blurry rear camera issue periodically since I bought my s7 about 6 months ago. After reading through the replies on this thread, I opened my camera app and gave it a firm tap in my palm and the camera cleared up. I'm convinced, as someone else mentioned, that the optical focus hardware get a stuck.
    07-09-2017 03:40 PM
  23. Dawa Nurbu Lama's Avatar
    Same issue with s8. tapping on the phone fixes it temporarily.
    12-19-2017 10:16 PM
  24. ItzMaya MRM's Avatar
    Tysm it worked!!!
    02-24-2018 12:05 PM
  25. Roska Posti's Avatar
    Wft! First i was like there is noway that this would work, but then i gave it a try and holy **** my camera works again!!!!! Thanks ))
    02-03-2019 05:36 AM
50 12
  1. Not a bad camera...
    By HiiPower in forum Moto G
    Last Post: 06-26-2015, 11:29 PM
  2. Replies: 1
    Last Post: 02-22-2015, 10:57 PM
  3. Replies: 1
    Last Post: 02-22-2015, 02:39 PM
  4. Samsung Galaxy s5 camera options
    By Marioclement23 in forum Samsung Galaxy S5
    Last Post: 02-22-2015, 11:52 AM
  5. Fuzzy Camera?
    By nmarie913 in forum T-Mobile Samsung Galaxy S4
    Last Post: 02-22-2015, 09:27 AM
