1. AC Question's Avatar
    Sir Please help me. yesterday i bought a Galaxy Note Edge SM-N915G in India and today i tried to root my Galaxy Note Edge SM-N915G using Odin 3.07 and CF Auto Root file (CF-Auto-Root-tblte-tbltedt-smn915g.tar) with proper way but It was unsuccessfull and not i am getting a message "firmware upgrade encountered an issue. please select recovery mode in kies and try again"
    sir now my device is only able to go in downloading mobe but it is unable to go in recovery mode. i remembered that i did a mistake that i have not checked the USB debugging under developer option. i also tried for emergency recovery through Kies3 but kies3 is not detecting my Note Edge. now i am helpless....plzzz help me.
    03-19-2015 04:51 AM
  2. sultan sadoon's Avatar
    Happened this same problem with me the solution is you remove the battery and then press power key and volume button down and home button together and then rode the battery will enter into the downloading mode and by odin program based process remaining and you should download the official rom for your device you may do so through the site sammobile.com
    03-19-2015 03:58 PM
  3. vkt222's Avatar
    Amazing sir thanx a lot......tried to flash stock rom through odin and it worked.....woooow....thanx a lot
    03-22-2015 01:31 PM
  4. shahzad kaleem's Avatar
    thanx alot. save my device
    07-29-2016 07:41 PM
  1. Replies: 1
    Last Post: 03-21-2015, 11:51 PM
  2. music app issue
    By buddhafella in forum Samsung Galaxy S5
    Last Post: 03-21-2015, 11:48 PM
  3. How To Retrieve Deleted Photos From My Galaxy s5?
    Last Post: 03-20-2015, 12:35 AM
  4. Why is my Galaxy Note 4 laggy with games?
    By Improve Ghost in forum Ask a Question
    Last Post: 03-20-2015, 12:03 AM
  5. Why can I not move Files to my phone?
    By Wtflolok in forum General Help and How To
    Last Post: 03-19-2015, 10:51 PM
