1. Ismael Pulido's Avatar
    Does FoxFi, Wireless Wifi mode work on the Verizon Galaxy Note Edge?
    I know it has work on other Samsung phones like the note 3 and 4. Thank you.
    03-25-2015 04:55 PM
  2. yostevo's Avatar
    Yes
    Ismael Pulido likes this.
    03-25-2015 10:23 PM
  3. Ismael Pulido's Avatar
    Have you seen it work or did you get your information some were else? The reason I ask is because I'm thinking of getting a Samsung galaxy note EDGE, and I really need Foxfi to work on it. It's a big experience for me and wouldn't want to spend the money if it doesn't work properly. Thank you for the previous response.
    03-26-2015 01:22 PM
  4. yostevo's Avatar
    I have seen it work on the Verizon note edge
    stronggeek likes this.
    03-26-2015 10:04 PM
  5. AlpineMan's Avatar
    I have a Verizon Note Edge that I use with Cricket (AT&T). I'm successfully using FoxFi on stock Verizon Note Edge ROM.
    Sent from my SM-N915V using Tapatalk
    04-06-2015 12:07 AM
  6. toddyt99's Avatar
    04-07-2015 08:16 PM
  7. toddyt99's Avatar
    I am purchasing a note 4 edge today. What do I need to do to bet a free hot spot. From reading rhe forum it looks like I need foxfi but I do not know how to do it. Can someone olease give me some assistance thanks
    04-07-2015 08:17 PM
  8. AlpineMan's Avatar
    Just install the free FoxFi app from Google Play Store. Launch it and configure your desired hotspot SSID and password.
    04-07-2015 09:22 PM
  9. toddyt99's Avatar
    04-07-2015 10:44 PM
  10. toddyt99's Avatar
    Does it work for sure on a new Verizon note 4 edge.
    04-07-2015 10:45 PM
  11. AlpineMan's Avatar
    It works on mine. I'm using my Verizon Note Edge on Cricket/AT&T.
    04-07-2015 11:08 PM
  12. Sharif Elkasaby's Avatar
    Does anybody know if Foxfi will work on the Samsung Galaxy Note Edge after Verizon's latest software updated?
    It does not work on the HTC One M8 and I'm afraid to update my software and lose using Foxfi.
    04-21-2015 01:59 PM
  13. stronggeek's Avatar
    Yes, it does. I've been using it off and on with no issues.
    "Does anybody know if Foxfi will work on the Samsung Galaxy Note Edge after Verizon's latest software updated?
    It does not work on the HTC One M8 and I'm afraid to update my software and lose using Foxfi."
    04-21-2015 10:08 PM
  1. Why is the sound on my Instagram Video recordings slow?
    By Ministar Magla in forum Samsung Galaxy S2
    Last Post: 04-02-2015, 03:07 PM
  2. can't hear the caller on Galaxy 3....
    By hybucket in forum Samsung Galaxy 3
    Last Post: 03-26-2015, 07:43 PM
  3. Why wont my samsung tablet 2 7.0 turn on or charge?
    Last Post: 03-26-2015, 12:26 AM
  4. Samsung Still Working On T-Mobile's Note 4 Lollipop Update
    By ttrimmer in forum Samsung Galaxy Note 4
    Last Post: 03-25-2015, 08:20 PM
  5. Replies: 1
    Last Post: 03-25-2015, 04:35 PM
