04-23-2015 10:05 AM
47 12
tools
  1. willmsbrg's Avatar
    A 1200mb download is hitting my phone as I post this!
    04-08-2015 07:18 PM
  2. willmsbrg's Avatar
    Screen shot
    Attached Thumbnails At&t lollipop is here-screenshot_2015-04-08-20-19-51.jpg
    04-08-2015 07:21 PM
  3. eljeffe58's Avatar
    That's good news for all of us.
    04-08-2015 10:07 PM
  4. Harry_Yambag's Avatar
    Was it Lollipop?
    Captivate me likes this.
    04-09-2015 11:24 AM
  5. Captivate me's Avatar
    Was it Lollipop?
    Yes it's the Lollipop update.
    04-09-2015 01:06 PM
  6. Bradley 916's Avatar
    Got the download and updated w/o issue. Charging phone back to 100%. Now it's time to explore Lollipop!
    04-09-2015 01:10 PM
  7. GSOgymrat's Avatar
    I just got the update a few minutes ago.
    04-09-2015 04:26 PM
  8. cgooge14's Avatar
    1189MB for me is halfway done!
    04-09-2015 07:42 PM
  9. vasekvi's Avatar
    Observations:
    I noticed the camera shutter button got moved to the screen. They would have allowed for more settings on the edge panel when they did that.
    Edge notifications can now be turned off. I'm thankful for that. Redundant too since Lollipop previews incoming messages nicely.
    Haptic feedback is nicely adjustable although I think it's messing with my SwiftKey haptic feedback settings.
    Much smoother though I am happy with the update.
    Sent from my SAMSUNG-SM-N915A using Tapatalk
    04-10-2015 12:25 AM
  10. bfuels1993's Avatar
    I noticted the same thing last night after I downloaded the update. I'm not sure I like it,I got use to it being on the edge and liked it better that way. I would like to have the option to move it back .
    04-10-2015 10:18 AM
  11. vasekvi's Avatar
    At times the shutter button on edge screen is awkward. I'll have to use my camera for a few days to see how I like it now.
    Sent from my Samsung GALAXY Note Edge on AT&T
    04-10-2015 10:23 AM
  12. Michael Pinette's Avatar
    Just got the update wish they would have kept the shutter button on the edge screen seemed more comfortable
    04-10-2015 08:22 PM
  13. vasekvi's Avatar
    At least there are cool transitions between front and rear camera and the shutter sound I like better lol
    04-10-2015 08:43 PM
  14. Klauslaw1's Avatar
    The update just rendered my phone useless. Won't keep a charge. Had to reset bc contacts kept updating and couldn't text. F ing Google releasing **** b4 it works.
    EsEllEmm and NotAnAppleGuy like this.
    04-10-2015 09:01 PM
  15. Cyco9's Avatar
    Thanks for the update Klaus. I imagine I'll be staying away from lollipop for a while. It sounds like it makes a lot of the edge features and functionality useless.
    Bummer, I was looking forward to some of the updated features but I've heard enough people post complaints so I'll pass for now.
    04-10-2015 09:41 PM
  16. Haalcyon's Avatar
    I've not had my Note Edge on for a couple days. Fired it up this morning and the download is-a com'n. Now my Note Edge will join my Note 4 and Note 3 in Lollipop greatness...I hope.
    📐🍷from the sliQ side of womb with the n.Edge🍶📏
    ladyc0524 likes this.
    04-11-2015 06:32 AM
  17. glidersgalore's Avatar
    Wish I would have skipped the update. I like someof the stuff but hate the pop up notifications. I liked when they were on the edge screen
    04-11-2015 03:05 PM
  18. t1328's Avatar
    My experience with the regular Note 4 is that after doing a hard reset post Lollipop update, not only were new issues resolved, but overall performance increases dramatically and lag is all but gone now. I highly encourage all of you guys to backup your phones post Lollipop update, hard reset, and restore.
    04-11-2015 03:43 PM
  19. Cyco9's Avatar
    I don't look forward to doing a hard reset but I might end up doing that. I woke up this morning to lollipop already updating even after I told it not to. So far everything seems smooth with no hiccups.
    Like I said though, I'm not a fan of the lack of Edge features after the update.
    It's completely silly of Samsung to push out an update for an Edge phone that strips away the functionality of the Edge. Seems like they just pushed us the Note 4 update.
    On the bright side, It does seem a good bit faster though.
    04-11-2015 06:29 PM
  20. Cyco9's Avatar
    Did they take away the music controls from the lock screen or is it just my unit acting up?
    04-11-2015 06:46 PM
  21. Haalcyon's Avatar
    I'm cautiously optimistic that Lollipop didn't bork my AT&T n.Edge. So far so good.
    04-12-2015 06:38 AM
  22. paradroid's Avatar
    I kept refusing the update. I should have found a setting to block the update but didn't have the time and thought I would need to accept the update. Then it updated without my permission during the night last Thursday.
    I am not sure what advantages of this update is. Some of the already limited edge functionality we had was taken away and battery life is the same. Also, my quick data enabler widget is now blocked and now I need to dig deep in the menu to switch data on/off.
    Anyone know of any new advantages of this update?
    I need to root more than ever now to fix the phone.
    04-12-2015 11:21 AM
  23. Haalcyon's Avatar
    One HUGE advantage (huge for me anyways) is that you now have FULL access to your SD card and so do any 3rd party apps that you choose.
    04-12-2015 01:16 PM
  24. road_kill's Avatar
    I got the update...forced on me, the only thing im getting is some lag and a stupid playstore error for apps that i dont want to update. The android pain. Other then that im actually liking it. Although i do think i might do a factory reset.
    04-12-2015 01:38 PM
  25. paradroid's Avatar
    I didn't even know I did not have full access to my sd card before. It seems I could always get to all my files on the card. What does full access to sd card give me that I did not have before.
    04-12-2015 01:55 PM
47 12
  1. My g tab 7 just got lollipop!
    By smchambers56 in forum LG G Pad 7.0
    Last Post: 09-13-2015, 02:32 PM
  2. Haven't received lollipop update for HTC One M8 AT&T :-(
    By Charlie Countryman in forum Ask a Question
    Last Post: 04-13-2015, 04:00 PM
  3. HTC One M8 Lollipop Update for AT&T
    Last Post: 04-09-2015, 12:08 AM
  4. Instagram after lollipop update
    By godsidekurt in forum Samsung Galaxy Note 4
    Last Post: 04-08-2015, 07:25 PM
  5. Replies: 1
    Last Post: 04-08-2015, 07:12 PM
