1. EsEllEmm's Avatar
    Instead of showing the temperature, it just continually tells me to tap here to add weather. I did tap there... I set the stupid settings... Still no weather.
    Well, there goes one of the things I liked most about the edge display.
    04-10-2015 07:59 PM
  2. Michael Pinette's Avatar
    My still works fine, however at night when I use the edge for night clock it use to show the weather temp now it just shows the time and date.
    04-11-2015 11:58 AM
  3. EsEllEmm's Avatar
    Seriously!? Mine is doing that too, but I assumed it was just because the weather is not showing up at all.
    I loved having the current weather on the night clock display. It was nice to look over at the phone first thing in the morning and see what it was like outside. Why are they taking good features away with new updates!?
    04-11-2015 09:14 PM
  4. EsEllEmm's Avatar
    Well, I did a factory reset, still nothing! It just keeps telling me to tap here to add weather info. It doesn't matter how I set it. it never actually gives me weather info.
    Is it even worth taking it to an AT&T store, or will they just assume I don't know what I'm doing and then look dumbfounded when they realize that the phone is truly not working correctly?
    04-19-2015 08:55 AM
  5. EsEllEmm's Avatar
    Finally found the solution from another forum. Apparently if you never set up the factory weather widget, the weather on the edge screen no longer works on lollipop. So, all you have to do is set up the widget, and the weather on the edge comes back. You can even delete the widget afterwards, but you have to at least set it up.
    04-19-2015 09:40 AM
  6. Sammytheorangutan's Avatar
    Mine doesn't ask to add info but after the 5.0.1 update, it doesn't show up on the night clock. Odd. Probably a work around but I dunno what it is. I miss it.
    04-20-2015 04:30 AM
  7. vel7wil's Avatar
    Broken on the Sprint update as well. .....sucks:banghead:
    Sent from my Note Edge using Xparent Skyblue Tapatalk 2
    04-22-2015 07:17 AM
  8. ChiTy14's Avatar
    Thanks but I seem to have done this and I still cant get the weather so show up on the edge during my night clock hours. Any ideas or link to where you found the forum, maybe it has more detail for morons like me? Thanks!!
    07-21-2015 11:07 PM
  9. SMyat's Avatar
    I set the weather widget up but still nothing is happening on the edge screen and it's soooo annoying
    08-28-2015 12:07 AM
  10. jaj_ne's Avatar
    I added the weather widget and now the edge shows the temperature. Thanks for the tip.
    AT&T 5.0.1
    08-29-2015 12:18 PM
  11. Cfrankfly's Avatar
    My broke too.....
    11-05-2015 09:51 PM
  1. Replies: 6
    Last Post: 08-30-2015, 03:39 PM
  2. Lollipop Discoveries
    By me75006 in forum LG G3
    Last Post: 04-12-2015, 01:02 AM
  3. Transferring SPlanner content from S5 to S6 Edge
    By Selena N in forum Samsung Galaxy S6 edge
    Last Post: 04-11-2015, 09:05 AM
  4. LG volt. how do I get the voice input key work
    Last Post: 04-10-2015, 10:35 PM
