1. Gumbyshu's Avatar
    Just got my Note Edge and am loving it. I tried out the fingerprint scanner, but found that it was just as inconsistent a security measure as the pattern unlock on my old Note 2. It worked for the first three times I had it on my phone, but I was able to get into the phone with a swipe or by tapping on an app from the edge screen. Plus, my daughter wants to play on my phone and I don't want to be the only one who can unlock it.
    The issue is that the swipe option in the lockscreen menu is greyed out and says, "option turned off by administrator" or something similar. I've tried turning it back on, but I can't find the option to do so. Anyone have any ideas?
    04-22-2015 09:56 AM
  2. copprtop116's Avatar
    Found it . It's under settings and security you have to clear all credentials .
    Joey 2120 likes this.
    04-22-2015 04:12 PM
  3. lapeter's Avatar
    Thanks you for this. I thought when you used Foxfi that you had to use the fingerprint lock. Much better now.
    04-22-2015 06:38 PM
  4. Gumbyshu's Avatar
    Thank you! That worked!
    04-23-2015 01:42 AM
  5. April Showers's Avatar
    Thanks
    09-03-2015 04:36 AM
  6. Joey 2120's Avatar
    How do I bring back the ripple effect back? I have seem to have lost that after putting the lock.
    09-24-2015 12:13 AM
  7. SHEMARIAH's Avatar
    Thank you so much. This was indeed very helpful.
    11-05-2015 10:53 AM
  8. SHEMARIAH's Avatar
    Thank you so much copprtop116. This information was indeed very helpful.
    11-05-2015 10:55 AM
  9. Cshill69's Avatar
    So very helpful! I've been trying to do this for so long
    05-18-2016 03:51 PM
  1. How do I save my Google Play music to an sd card?
    By AC Question in forum Google Play Store
    Last Post: 06-24-2015, 01:47 PM
  2. Why will my S6 focus on my selfie mode?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 04-23-2015, 02:47 PM
  3. Why can't I connect to Google?
    Last Post: 04-22-2015, 11:40 PM
  4. Replies: 1
  5. Replies: 3
    Last Post: 04-22-2015, 12:32 PM
