Anybody have problem with FitBit App on Edge?
My fitbit was working fine syncing when it was with the rest of the apps. I use it often enough I put it in a folder with a couple of other apps on the edge and it wouldn't sync anymore. So I removed it out of the folder and off the edge and rebooted the phone and tried it again and it worked fine. Anyone else have this problem?
Re: Anybody have problem with FitBit App on Edge?
I keep mine on the edge and I've not had any problems with it. Haven't tried putting it in a folder though.
Never tried putting it in a folder nor on the edge. Works just find.
