A
AC Question
Accidentally Deleted my System - Note Edge
Hello! It has NOT been a very good day for me. My Note Edge, from Canada, was acting up a little, with a little bit of a lag issue. I decided to reset the settings using TWRP, (yes, I rooted then unrooted my phone but kept TWRP). However, I accidentally went into the custom wipe, and wiped my system as well as the dalvik cache and cache, therefore wiping my OS as well.
So, I looked up some instructions but found none specific to the note edge. I tried flashing a Lollipop build with ODIN but it continued to read 'FAIL" and the process was unsuccessful.
Please. If there is any way I could solve this problem, I would be grateful.
Thank you.
Thank you.
