1. AC Question's Avatar
    I want to transfer and backup files from my Galaxy note edge to my mac pro
    06-05-2015 03:12 AM
  2. P_Devil's Avatar
    There are multiple ways. You can directly plug it into one of your Mac's USB ports, you can transfer stuff to a memory card and plug that into your Mac, or you can even use a cloud service such as Dropbox or OneDrive (I use OneDrive to transfer stuff from my Note Edge to my Surface 3).
    06-05-2015 12:43 PM
  3. JALUK's Avatar
    I use the free Android Storage Made Easy Cloud App. It comes with a built in FTP Server. I simply ensure my phone and macbook are on the same network and then switch on the dedicated FTP server that comes in-app and use Cyberduck on the Mac to connect. No wires, no cables, its easy.
    06-08-2015 10:29 AM
  4. Bong Bubble's Avatar
    Can't you just bluetooth it?
    06-09-2015 04:23 AM
  5. vasekvi's Avatar
    Why don't you just use drive or box.com?
    Sent from my Samsung GALAXY Note Edge on AT&T
    06-09-2015 06:12 PM
  6. Hghlndr's Avatar
    Hey... make it EZ on yourself: been using Samsung's own SideSync 3.0 for the last year and I have a MacBook Pro and a N3. Use the USB cable as it's faster transfer than Wi-Fi and you can see the home screens projected onto your Mac! Plus other treats as well. After Samsung's 8/13 event they have upgraded it to sidesync 4.0 check it out. Good luck
    08-16-2015 12:35 AM
  1. How do i reset the credential storage password ?
    Last Post: 06-11-2015, 02:32 PM
  2. Do you turn off your data connection?
    By darwincruz20 in forum General News & Discussion
    Last Post: 06-09-2015, 08:08 PM
  3. Samsung note 4 move box for received call
    By Izzie2106 in forum Samsung Galaxy Note 4
    Last Post: 06-05-2015, 06:35 AM
