1. Nina Ochoa's Avatar
    I'm trying to get some songs from my computer to my music library on my Galaxy Note Edge but when I connect my USB to the phone, the computer doesn't recognize it. Neither does my phone. I've tried 4 different USB chords, including the one that came with the phone. I've downloaded Keis3 and SmartSwitch but still nothing registers. When my phone is plugged into the computer it charges but it doesn't give me any option to connect to USB/PC in the notification panel.
    07-14-2015 08:42 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. What PC do you have?
    07-14-2015 08:48 AM
  3. Nina Ochoa's Avatar
    Hi Golfdriver and thank you. I'm on my work computer, it's a Dell Windows 7.
    07-14-2015 09:12 AM
  4. Hghlndr's Avatar
    Hey Nina! Simple try Samsung's SideSync 3.0 and you'll be good to go. You may Jane top delight of your computer any other software used top connect: Kies, AFT, etc. Good luck.
    08-19-2015 04:34 AM
  5. Hghlndr's Avatar
    That was have to delete any other.
    08-19-2015 04:35 AM
  6. wms3's Avatar
    Another alternative is the app Wi-Fi file explorer. It will allow you to access your phone from the web browser on your desktop computer, as long as your phone and computer are on the same network. No USB connection required.
    Posted from my Sammy Note 4
    08-23-2015 12:25 AM
  1. Changed to new phone without backing up messages on old
    By kengalway in forum WhatsApp for Android
    Last Post: 08-15-2015, 03:54 PM
  2. Replies: 14
    Last Post: 08-02-2015, 08:52 PM
  3. What can I do my Samsung Galaxy S GT-19000 shuts down?
    By AC Question in forum Samsung Galaxy Tab
    Last Post: 07-17-2015, 08:18 AM
  4. Can I upgrade mi S5 from Spain to Adnroid 5.1 from T-Mobile?
    By baartu95 in forum Samsung Galaxy S5
    Last Post: 07-14-2015, 09:43 AM
  5. ASUS 7 Memo - is locked on voice control, how do I reset it?
    Last Post: 07-14-2015, 08:28 AM
