1. eljeffe58's Avatar
    I took all the folders out after a fell reset, in the actual edge. How can I create a new folder for the edge per se?
    07-28-2015 09:39 AM
  2. Dave-in-Decatur's Avatar
    Click the star at the top of the edge panel in which you want to put a folder. That will bring up a screen with available apps, and with the current setup of that panel on the right. Tap and hold an app icon in that current setup panel; a Create folder option will appear at the top, and you then drag the selected app icon all the way up to that folder at the top of the screen. This creates a folder with that app in it in the panel. You can then drag other apps into it. The key is you have to start with an app that's already in the panel and which you want to put in the new folder.
    eljeffe58 and kieso like this.
    07-28-2015 11:30 AM
  1. Am I the only one that likes the invite system?
    By zachthebomb13 in forum OnePlus 2
    Last Post: 08-15-2015, 01:45 PM
  2. OnePlus 2 takes 3 HOURS to fully charge
    By smooth4lyfe in forum OnePlus 2
    Last Post: 08-10-2015, 10:38 PM
  3. Should I run for the new Moto G or is just the rush?
    By WP_290 in forum General News & Discussion
    Last Post: 07-30-2015, 08:20 AM
  4. Moto X Play Specs
    By belodion in forum Moto X Play
    Last Post: 07-28-2015, 03:04 PM
  5. Receiving multiple texts in a thread.how can I stop this?
    By jackofalltrades9 in forum Moto 360
    Last Post: 07-28-2015, 09:15 AM
