1. Tina Ferreira's Avatar
    Is anyone else having issues with freezing lately. The phone itself seems so slow now.
    Am I the only one?
    08-20-2015 07:51 PM
  2. 88dale88jrfan's Avatar
    Mine hastoo. I even called verizon. They remotely went in my phone,downloaded all apps ND contacts. Then wiped all software. Then installed NE software. But since lollipop update it ducks still
    08-20-2015 08:26 PM
  3. george99's Avatar
    Mine sucks since the 5.1 update. I wanna try downgrading to Kitkat but im not sure if it will work.
    08-21-2015 09:31 PM
  4. DAS's Avatar
    Since the update my phone has also been very jittery. My battery life is abysmal, and the Samsung keyboard keeps looping and force stopping that I almost bought a Note 5 today.
    08-21-2015 11:27 PM
  5. Sleepwlkr45's Avatar
    Yes. Same problems.
    08-23-2015 12:41 AM
  6. kieso's Avatar
    Yeah I'm pretty disappointed in performance also. After the lollipop update I did do a factory reset but I still get "unfortunately x has stopped" errors. And the battery life sucks for me to.
    08-23-2015 10:43 AM
  7. george99's Avatar
    I will never do a major OS update again on any phones i have. Kitkat was AMAZING on this phone. The updates have ruined everything. I cant get the stock Kitkat software to flash via Odin either so im stuck!
    08-23-2015 07:04 PM
  8. DAS's Avatar
    I performed a factory reset and my experience has been that the performance of the phone has improved dramatically.
    The OS is much smoother, the battery life is amazing, and the freeze ups have ceased.
    I took the recommendation to perform a factory reset at the suggestion of the representative at the Samsung Experience Shop. I didn't think it would do any good, and I almost ignored him completely, but I'm glad I took the plunge and did the update.
    08-23-2015 08:23 PM
  9. george99's Avatar
    Are you running 5.1? I did like three resets, it still freezes up. Maybe ill try it again
    08-23-2015 08:58 PM
  10. DAS's Avatar
    Yes. 5.1.
    I am surprised it hasn't worked for you. To be honest I didn't think it would work for me, but my phone was in such bad shape I was deperate to try anything.
    I would suggest trying it again, and see what you get. By the way, are you using an OEM battery or third party? They will also make a difference.
    08-23-2015 09:26 PM
  11. neoberry99's Avatar
    Very true.
    08-23-2015 11:30 PM
  12. george99's Avatar
    Yup, stock battery and everything. I reset it again numerous times last night and it hasn't frozen and I have my edge notifications back. There are a few little glitches but it's better. I'm scared to have to restart the phone because when I did that last time, the edge notifications stopped working.
    08-24-2015 11:55 AM
  13. DAS's Avatar
    I hope this is the last time you have to perform a factory reset. They are painful I know, but if it means the phones will perform better then you can feel like it's worth it.
    I wish you the best!
    08-24-2015 02:20 PM
  1. Opening Pandora when phone is locked
    By bjybhs8 in forum Moto 360
    Last Post: 09-04-2015, 05:22 AM
  2. Replies: 1
    Last Post: 08-22-2015, 03:13 AM
  3. Can I use a 3000mah battery for an LG p716 phone?
    Last Post: 08-20-2015, 06:43 PM
  4. How can I fix my phone
    Last Post: 08-20-2015, 06:38 PM
  5. Why won't my phone boot normally?
    Last Post: 08-20-2015, 06:06 PM
