1. AC Question's Avatar
    i have the samsung not edge and for some reason when i receive text message it doesn't vibrate. i havent change any settings to stop it from vibrating.
    10-18-2015 06:56 PM
  2. UJ95x's Avatar
    Welcome to AC!
    What messaging app are you using?
    10-18-2015 07:08 PM
  3. tunoob's Avatar
    i am using the default messaging app.
    10-18-2015 08:20 PM
  4. UJ95x's Avatar
    Did you make sure to go into the settings and checking that it didn't get turned off by accident?
    10-19-2015 03:36 AM
  5. tunoob's Avatar
    yeah all the settings is the way it should be.
    10-19-2015 04:46 AM
  6. UJ95x's Avatar
    Do you at least get the notification telling you the message came in?
    10-19-2015 01:58 PM
  7. tunoob's Avatar
    yeah whenever my friends text me or when i text myself to test if the vibration work the notification does show up. when i use other messaging apps such as bbm, whatsapp, etc it vibrates . also when someone calls me it vibrates. its just the text message that doesn't vibrate. tried turning on and off the vibrate message setting it didn't do anything. did the same thing restarted phone also didn't do anything. i dont really want to system restore my phone to get it working
    10-19-2015 06:26 PM
  8. UJ95x's Avatar
    That's really weird. Well, you can also try installing a third party messaging app. Google Messenger and Textra are both great IMO. You could test that to at least see if it works
    10-20-2015 03:15 PM
  9. tunoob's Avatar
    so ive tried using textra. it vibrates when i get text messages. but now it wont show my message on the edge.
    10-21-2015 01:03 AM
  10. UJ95x's Avatar
    Oh, yeah. I'm not sure which apps are supported for that notification service.
    Go to settings > applications > messaging (the original one) and hit clear cache on the app. Then try that one again
    10-21-2015 10:22 AM
  11. tunoob's Avatar
    thanks that worked
    10-22-2015 01:54 AM
  12. UJ95x's Avatar
    thanks that worked
    Awesome! See you around the forums
    10-23-2015 11:13 AM
  1. How do I increase the file size to send a video in messages?
    Last Post: 10-18-2015, 07:11 PM
  2. How can I clear my internet history?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 10-18-2015, 07:04 PM
  3. Replies: 1
    Last Post: 10-18-2015, 07:02 PM
  4. Galaxy Note 4 Picture Tags Mysteriously Disappeared
    By colpolmen in forum Samsung Galaxy Note 4
    Last Post: 10-18-2015, 06:54 PM
  5. I have a droid x pro and the power button is broken, any fix?
    By emilyburgett in forum Ask a Question
    Last Post: 10-18-2015, 06:45 PM
