Edge is heating up & Battery is draining, what do I do?
A
AC Question
Edge is heating up & Battery is draining.
What apps are the ones that drain your battery life & ones that gets the cellphone warm?
Talderon
1,086
100
63
Re: Edge is heating up & Battery is draining.
That is a very open ended question. What you can do is go to Settings > General > Battery and see what apps are using the most power.
There are some cleaner apps out there that can help. I am using Lookout (came with the phone) and am really happy with it.
fallingOutOfLoveWfithTech
