1. AC Question's Avatar
    Sometimes my back button works and sometimes it does . why?
    11-05-2015 11:28 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try booting into Safe Mode, which temporarily disables all 3rd party apps. https://support.t-mobile.com/docs/DOC-14748
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    11-06-2015 02:31 AM
  1. Problems flashing MOAR ROM for Galaxy S5 (sm-g900v).
    By ccurtis11 in forum Samsung Galaxy S5
    Last Post: 11-06-2015, 09:07 PM
  2. Replies: 1
    Last Post: 11-06-2015, 09:33 AM
  3. Replies: 1
    Last Post: 11-06-2015, 09:32 AM
  4. Why my note 5 wont turn on?
    Last Post: 11-06-2015, 02:44 AM
  5. Replies: 1
    Last Post: 11-06-2015, 02:32 AM
