1. ImJustAmir's Avatar
    Hi. I have a problem with my Note Edge and I searched everywhere but didn't get any answer.
    My house has a good LTE coverage and it doesnt really switches from LTE to 3G. But only when I dont use it. I usually use mobile hotspot to share the LTE internet with my laptop and I dont have a problem with LTE, so I dont really use my phone a lot. But when I do, it just switches from LTE to 3G. So to get it back, I have to change "Data network type" from LTE/3G to 3G, then change it back to LTE/3G. After a minute, if I use the phone, it happens againI have to do the same thing. Sometime it doesnt even connects to LTE. I just have to do it many times to connect to 4G. It really annoys me.
    I could use some help. Thanks.
    06-19-2016 07:11 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Moved this to the Note Edge forum.
    When you say the phone switches from LTE to 3G when you use it, are you just trying to use web-connected apps (e.g., the browser)? Or are you making a call on the phone and also trying to surf the web at the same time?
    06-19-2016 10:21 PM
  3. ImJustAmir's Avatar
    When I making a call, it allways switces to 3G but when the call ends, it switches back to LTE. But my problem allways happens when I'm using the web-connected apps. Like whatsapp, chrome or etc.
    It never happens when I'm using these apps or anything else on my laptop.
    06-20-2016 05:10 AM
  4. neoberry99's Avatar
    Is your phone updated to the latest OS? I used to have similar problems before upgrading
    Posted via me
    06-20-2016 06:52 AM
  5. B. Diddy's Avatar
    Which carrier do you have? Do you have VoLTE/Advanced Calling/HD Calling turned on (or is the phone capable of it)? If not, then the phone is probably dropping to 3G in order to utlilize its voice capability. See this thread: T-Mobile, drops from LTE to 3G when making a… | Google Nexus 5
    neoberry99 likes this.
    06-20-2016 11:58 AM
  6. ImJustAmir's Avatar
    no I don't have the latest because I can't update. I get an error when trying to search for updates and I don't wanna use a firmware to update the OS
    06-20-2016 02:50 PM
  7. ImJustAmir's Avatar
    no I don't have those. I have Irancell (I live in iran)
    06-20-2016 02:52 PM
  8. B. Diddy's Avatar
    That's probably why it drops to 3G when you're on a call.
    06-20-2016 03:45 PM
  1. how to protect the home buttom of my samsung a5 2016 from scratches?
    By amr ashraf mostafa in forum Samsung Galaxy A5
    Last Post: 06-21-2016, 10:45 AM
  2. Decided to keep the Moto 360
    By cohoman in forum Moto 360 (2015)
    Last Post: 06-21-2016, 10:04 AM
  3. Note 4 stays awake and drain battery when idle
    By numan2003 in forum Samsung Galaxy Note 4
    Last Post: 06-20-2016, 01:51 PM
  4. Replies: 0
    Last Post: 06-19-2016, 06:55 PM
  5. Advice on screen protectors & cases for S7 Edge.
    Last Post: 06-19-2016, 03:57 PM
