Honestly it's a tall S7 with an Spen. That's it. I'm still using my Edge right now but I'm left with no choice to but to go ahead and activate this "phone".
Be mindful. The N7 is nowhere near as wide as the Edge. This means typing up texts is extremely uncomfortable because the N7 is literally the width of an S7. I only use PIN security so fingerprints and eyeballs mean nothing to me.
If like me you have ALL your apps on the panel and nothing on the home screen, you better get your life in order because you can only have 10 apps on the "apps" panel vs 20 on the Edge x 5 panels. That's it, 10 apps and nothing else.
The settings menu is totally redesigned and takes some getting use to. If you NEED a phone with an Spen, this is the way to go. If you need a NOTE, stay with the Edge, 4 or 5. The days of the LARGE PHABLET are officially over...
