Serious help needed regarding Samsung Galaxy Note Edge
A
AC Question
Hello
i have a Samsung Galaxy Note Edge N915F
I'm using it in India
Whenever I try to update my phone it says "Latest updates have been installed"
The phone is still running on Android 5.0.1
how do i get Android 6.0.1 (Marshmallow)
its Baseband Version is N915FXXU2BOJ7
please someone help me.
I want the latest updates, how can I install Marshmallow
Thank You
Tim1954
Q&A Team
Jan 17, 2016
6,924
Go to Sammobile and enter your model number (N915F). If there is software available you will see it there. If you are network locked, they will eventually push the updates to you. If not, you may be able to update from Sammobile site... I'd just keep checking for update and wait patiently...
