1. AC Question's Avatar
    Hello folks,my note edge keeps draining my battery hard,like 10% in minutes,the battery is new so thats not the problem,the battery status doesnt show what consumes my battery,any tips?Also my phone shuts down at like other numbers than 0 percent.
    04-15-2017 02:35 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Is it an OEM battery? 3rd party batteries might have more chance of being faulty.
    It's help to see some stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    04-15-2017 04:23 PM
  1. Replies: 2
    Last Post: 03-13-2018, 09:24 PM
  2. Green circle white fan icon on note 4
    Last Post: 11-11-2017, 06:40 PM
  3. Replies: 7
    Last Post: 04-17-2017, 05:08 AM
  4. Galaxy S6 Edge- Screen is stuck and won't soft reboot
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 04-15-2017, 05:08 PM
  5. Samsung S6 edge Internal Memory says 8gig full.
    Last Post: 04-15-2017, 05:06 PM
