1. AC Question's Avatar
    Once the battery level is below 80% my phone goes off and can only be switched on if I put it on charge
    07-13-2017 01:37 PM
  2. PJRed2008's Avatar
    Welcome to the forums. Have you kept track of how long it takes to get there from 100%? Just wondering if your battery indicator is lying about the charge level. Also, you can set alarm/power off levels in Settings. Maybe check there to see what that is set on.
    If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
    07-13-2017 01:52 PM
  3. PJRed2008's Avatar
    Mod Note: Thread moved for better visibility.
    07-13-2017 01:56 PM
  4. KennyG4545's Avatar
    Once the battery level is below 80% my phone goes off and can only be switched on if I put it on charge. Do anyone have ans to this question please.
    03-14-2018 06:49 PM
  5. neoberry99's Avatar
    You gotta replace your battery. Try finding OEM replacement. It won't be easy especially using Ebay and Amazon as they carry a ton of fakes.
    04-29-2018 04:50 PM
  6. NexusGirlX's Avatar
    Yes, you really have to be careful. They will say they are OEM batteries but so many are not. One of my so called OEM batteries started to swell. I don't use my Note Edge anymore so it wasn't that big of a deal to me. Any batteries that you do find will be a few years old now at least since Samsung quit selling them a few years ago.
    04-30-2018 06:51 AM
  1. Replies: 3
    Last Post: 12-10-2017, 03:08 PM
  2. Why the Mate 9 is severely underrated
    By dpham00 in forum Huawei Mate 9
    Last Post: 07-16-2017, 12:43 PM
  3. Replies: 0
    Last Post: 07-13-2017, 01:34 PM
  4. Replies: 0
    Last Post: 07-13-2017, 01:25 PM
  5. Why doesnt my phone light up when ringing
    Last Post: 07-13-2017, 01:20 PM
