Tempered glass
Ms Charli
394
17
I'm looking for tempered glass screen protector for my note edge. Any suggestions as to where I can order a good quality tempered glass screen protector?
Thanks for responding! Amazon is the first place I checked they have nothing only for the Note 4. 😔 I have googled and found poor rated tempered glass but mainly nothing.
Not familiar with the Note Edge, but if the edges are curved like the S7e then you won't find a glass protector that will stay on. They work well for flat screens but not with any curve. There are, IMO, very good non-glass protectors, I use ArmorSuit, but there are other very good ones, and they're much less expensive.
I've successfully used the following glass screen protector; it stays on nicely and covers the curved edge of the screen. You can find it on Amazon under Note Edge Screen Protector. Was only $7.99 with free shipping with Amazon Prime.
"Dogxiong Black Full Cover Connect Curve Edge Anti-scratch Inner concave Design Glass Screen Without Gap Tempered Glass Protectors Guard Film For Samsung Galaxy Note Edge N915"
blåhaj
