11-30-2018 12:19 PM
172 ... 567
tools
  1. SHIVA77's Avatar
    muzzy, It's possible that something got damaged. I am thinking of resetting the tablet to see if that does anything. But it runs so good. 3 years and two months old and it runs like new... except for the issues I caused while swapping the battery.
    beut, the problem is not the sim card is the sim card port.
    05-09-2017 03:14 PM
  2. Beut's Avatar
    It's a chain of serial connections, you should start at the starting point of failing.
    Otherwise, you have no clue where problem comes from. I had the same problem before, a failing SIM slot causing the HOME button not working.
    It's up to you, I just try to point you in a right direction. Sooner or later, you'll see.
    Anyway, Reset has nothing to do with bad connections.
    05-09-2017 07:27 PM
  3. SHIVA77's Avatar
    beut, I have looked at every connection at least 20 times. checked and rechecked. where was your problem from?
    05-10-2017 05:52 PM
  4. Beut's Avatar
    Check for each connector, you need a magnified glass, they are plugged connectors, press down the wrong way will bend pins of the male connector. I see very often of this damage by inexperienced users.
    Trust me, try the SD and SIM slot first as problem starts from there.
    I bought a Note Pro with not working HOME button. With all spared cables available, it took me only 5 minutes to find out where the problem came from.
    If everything worked before, it probably you damage one connector when re-assembling cables.
    This puzzle nobody can help you except yourself by doing one by one until problem found.
    I bought 7 defective Note Pros with ease, so I'm very confident with my judgement of Samsung tablet problems.
    Samsung Note Pro 12.2: Screen flickering problems-7-note-pro.jpg
    05-10-2017 08:20 PM
  5. SHIVA77's Avatar
    That makes sense.
    Will look into it.
    05-10-2017 08:28 PM
  6. SHIVA77's Avatar
    beut, would you narrow the issue to L shape orange/gold connector cable or the USB flex?
    05-10-2017 09:42 PM
  7. Beut's Avatar
    After the battery was reconnected, Home button and Sim card slot don't work.
    Based on your description, I know it starts from here or your USB charging flex, but the SIM, SD flex is more likely the source. If the L shape cable is damaged, your SIM must be working as it is at the beginning of serial connections.
    It's only $4 then you should try
    Sim Card Holder + Memory Card Holder for Samsung Galaxy Note Pro 12.2 P905
    05-10-2017 10:47 PM
  8. SHIVA77's Avatar
    Beut, I took the back off and looked at all connection with a magnifying glass, nothing was wrong.
    So, I ordered Sim car holder thanks.
    I need a second OEM charger for the Note Pro. Any other charger I use, even with 3.0 cable doesn't charger well. I am on eBay looking for it, there are some, but clearly not OEM.
    Anyone has a direct link to an OEM Samsung Galaxy Note Pro 12.2 USB 3 charger? TIA
    05-11-2017 09:51 PM
  9. Beut's Avatar
    You need this tool to verify the working condition of charger and cable
    USB Power Charger Current Voltage Detector Tester Monitor Meter for Phone Tablet | eBay
    The good reading should be 5.3 Volts if you're using 5.3 V charger, current should be 1.7 Amps. Micro USB cable can be used as no difference with USB 3 cable ( faster data, charging is the same ).
    Alternate cable and charger but you still have the same low reading, battery connector should be resoldered as it's the major problem of all Samsung tablets
    05-12-2017 07:14 AM
  10. SHIVA77's Avatar
    This item arrived and I installed it. But still getting the same issue, no SIM card warning and the Home button not working. Looked at the pins under magnifying glass it all looks good.
    Not sure what else can be done!
    05-18-2017 07:43 PM
  11. Beut's Avatar
    Then you have to try another USB Flex charging port. The key is you have to start at the beginning of this serial connection where the SIM is not recognized.
    05-18-2017 09:27 PM
  12. SHIVA77's Avatar
    Couple of updates:
    I reset the tablet for the first time ever. It didn't need it, as it runs like new. But wanted to get that option out of the way and the Home button issue was not resolved.
    Power / Charging
    For anyone looking for a replacement charger for the Note Pro 12.2 make sure to get a 5.3 Volt 2.0 Amp charger and a USB 3.0 cable. I have a bunch of Samsung chargers and cables but none of them could charge the Note Pro fast enough, even 5V 2Amps, to avoid the "slow charging" warning. The only one that worked good was the original charger which I still have and use. But I finally got a secondary charger from eBay after much research that is working great.
    Again if the charger just reads 5.0 V and 2.0 Amp will not be sufficient for fast charging. So hopefully this of use to some of you. 5.3 V and 2.0 Amp is also the output on the original charger.
    05-28-2017 02:36 AM
  13. treetopsranch's Avatar
    Odd that 3/10 of a volt could make that much difference.
    05-28-2017 10:05 AM
  14. Beut's Avatar
    5.3 or 5.0 Volts charger doesn't make difference as they have the same output max of 2 Amps.
    Try the 5 Volt and 5.3 Volts you will see the charging current is only around 1.7 Amps.
    The 5 Volts has charging current under 1.7 Amp, it must be a defective one.
    Be careful with USB cable, they may look identical but the drawing current is different.
    I bought many of them ( sold from China ) and see they can only draw 1.1 to 1.4 Amps, especially the one for Note Phone, it has only 1 Amp max, the cable is usually smaller in diameter.
    05-28-2017 03:59 PM
  15. SHIVA77's Avatar
    Well, I appreciate the arguments but none can match the real life results.
    (1) I own bunch of Samsung stuff (since I hate Apple) so have plenty of chargers lying around.
    (2) I have two that read 5.0 volt at 2Amp they couldn't keep up with charging the Note Pro 12.2 in the kitchen counter which is where it is when it's not by the bed side.
    (3) At the bed side is the original charger that reads 5.3 V and 2 Amp and obviously does a great job of charging.
    (4) When searching for a new charger I passed on all the 5v 2ampers and found one that read just like the original 5.3 and 2amp and came with a USB3.0.
    (5) This charger is as good and as fast as the original charger (feels a bit faster too).
    (6) Any other charger I tried on the Note Pro was too slow and I was getting the slow charge warning.
    (7) I think I may have found the actual Note Pro 12.2 charger replacement.
    eBay Link:
    https://rover.ebay.com/rover/1/711-5...3D471411869100
    05-28-2017 04:14 PM
  16. Beut's Avatar
    One thing I can tell: you can use a quality micro USB and it still charge the same rate as USB 3 cable.
    USB 3 cable only is faster in data rate; charging is the same as micro USB.
    05-28-2017 04:27 PM
  17. SHIVA77's Avatar
    all that was tried Beut. All variations of chargers that I have and cables. Nothing worked except for the original charger and the USB 3 cable. In some cases the tablet preferred USB 3 with my other Samsung chargers but still couldn't maintain charge while the tablet was being used.
    This one that I got from eBay is seemingly even faster than the original charger. Meaning not only can charger the tablet while it's being heavily used but seems to charge it faster when not in use.
    05-28-2017 07:21 PM
  18. Beut's Avatar
    I am having now more than 15 Samsung tablets, from my own experiences, as long as your USB port or tablet is in working condition, it doesn't matter which cable or charger I use. I use whatever available to use: micro USB, USB 3 cable, 5V or 5.3V charger, they're working the same. I have different models, not only the Note Pro which I have 5 to 6 of them, micro USB works fine with either 5V or 5.3V, as it has the max current of 2 Amps.
    Many people doesn't understand the difference, use the one for phone which only has max of 1 Amp.
    As long as you're using the right and working cable or charger, it's the same current draw: 1.5 to 1.7 Amps.
    05-29-2017 01:04 PM
  19. SHIVA77's Avatar
    we are talking apples and oranges in this particular case.
    (1) almost any charger will charge the phones or tablets, no one questions that. I was charging my Note Pro tablet by the kitchen using various Samsung chargers. I even have a 1 amp one.
    (2) if you are not in a hurry or not using the tablet extensively any charger will do the work. As they will eventually charge the tablet.
    (3) however, of all the chargers that I have only the Note Pro original charger can charge the tablet fast and also keep charging it and increasing the charge capacity while the tablet is being used extensively.
    (4) That was until I received the new charger from eBay. This thing works seemingly even better than the original Note Pro charger.
    (5) Any other comment re this matter is unrelated, since it misses my very exact point of argument.
    (6) I am done talking about this new charger and I am sure everyone else is tired of reading about it.
    05-29-2017 09:22 PM
  20. SHIVA77's Avatar
    For those who are following this thread. I found a great Home Button app to replace my broken physical Home Button. It's called Multi-Action Home Button app on Play. It's places a virtual button at the bottom center of your device and has ways to adjust it and also make it invisible. So basically I have the Home function back.
    06-17-2017 03:40 PM
  21. eyra akaba's Avatar
    you did an excellent job that most others can't. I'm glad that you solved the headache causing by this tablet.
    it sure has to do with the battery connector. I didn't want to do the soldering thing, didn't want to make a mistake so i opened the back and placed a piece of cut old matteress foam folded it and applied a strong adhesive tape to secure it over the connector and then replaced the back cover. I haven't had a single flicker since then. Been using it for nearly a month now. I can use it from 100% to 5% before charging, watch videos and really enjoy the tablet in a long time. Until the fix i tried almost everything in this forum without success. Device is 25 months old started having problem since it was 10 months old. Dealer couldn't fix it when i sent it there. They only flashed it and said everything was normal. Had been very frustrating buying a good and very useful device but with this issue. I think samsung should do better.
    I hope it works for any one who is having this frustrating issue.
    09-10-2018 03:16 PM
  22. Borotos Oenphatoris's Avatar
    Hi, I have this issues also since own a note Pro 12.2, my temporarily solving method is to curve the head of my charging connector, so it can connect and charge temporarily, Since its "THEIR" issue, not ours; Does any know they offer free fixing at Best buy or anywhere else? so this probelm can be resolved completely?
    Thanks
    11-30-2018 12:19 PM
172 ... 567
  1. Broken Screen on AT&T LG G2
    By LG G2 in forum LG G2
    Last Post: 03-11-2014, 08:27 PM
  2. LG G Pro 2 Knock Code
    By dctokyo in forum LG G2
    Last Post: 03-11-2014, 08:16 PM
  3. Samsung! Sponsoring The Cosmos
    By josephinstasis44 in forum General News & Discussion
    Last Post: 03-11-2014, 04:56 PM
  4. Thank samsung for there amazing service. :)
    By John Doe72 in forum Samsung Galaxy Note 2
    Last Post: 03-10-2014, 12:27 AM
  5. Note 3 Audio Codec Not Supported
    By jrmx17 in forum Samsung Galaxy Note 3
    Last Post: 03-09-2014, 10:00 PM
