Beut
Then you have to try another USB Flex charging port. The key is you have to start at the beginning of this serial connection where the SIM is not recognized.
it sure has to do with the battery connector. I didn't want to do the soldering thing, didn't want to make a mistake so i opened the back and placed a piece of cut old matteress foam folded it and applied a strong adhesive tape to secure it over the connector and then replaced the back cover. I haven't had a single flicker since then. Been using it for nearly a month now. I can use it from 100% to 5% before charging, watch videos and really enjoy the tablet in a long time. Until the fix i tried almost everything in this forum without success. Device is 25 months old started having problem since it was 10 months old. Dealer couldn't fix it when i sent it there. They only flashed it and said everything was normal. Had been very frustrating buying a good and very useful device but with this issue. I think samsung should do better.you did an excellent job that most others can't. I'm glad that you solved the headache causing by this tablet.
