07-01-2017 02:01 AM
35 12
tools
  1. tjmethod's Avatar
    It's all about the output of the charger- in general cell phone chargers on average were about 700 mA. The note smartphones com with a 2.1 A charger but could be charged with a 700 mA chargercharger but the the Galaxy and basically all android tablets won't charge unless they get 2.1A. There are 4A chargers out there and higher. These will charge faster. I find that a sizable good charging bank charges faster than an AC plug in charger anyway.
    02-22-2016 03:37 PM
  2. DennisOS2's Avatar
    So at this point is safe to say slow charging and fast discharging is strictly battery connection needing to be re-soldering and not a dying battery?
    03-31-2016 11:26 AM
  3. Beut's Avatar
    Battery has its certain life, most can be up to 2 years depending how you use your tablet.
    I had one battery that being discarded as dead battery by someone else. I fixed it by pushing all end tips closer to make good contact, then it works like new without any problem . Some people claim to fix the flickering screen by new battery but they don't know their old batteries can be fixed easily. Samsung fix this loose connection by silver conductive glue, I fix by pushing the opening closer
    04-01-2016 09:44 PM
  4. DennisOS2's Avatar
    Having followed this thread for quite a while and experiencing the same issues I decided to first purchase a new charge and cables. The cables are braided with substantial ends. This took care of the charging slowness completely. So I tried the new charger with older cables. Same charging issues. Then I switched back to the new cables and it charged just fine. This was ~2-3 weeks ago. I've noticed the one 'new' cable is a bit loose at the tablet end. With that came the charging issue again. Went to the other new, unused cable and the charging issue disappeared. When testing the fit of all my old cables, they all are loose fitting on the tablet side.
    There may also be internal soldering issues, but cables (temporarily) solved my charging issues. Now I have to figure out why the micro-USB ends are becoming so loose, when they seemed to last for months and months before.
    EDIT:
    The issue of new cables charging fine for a while (days to weeks of use) then failing to charge by first not being able to match power requirements when using the tablet. Charge on the battery begins to decrease slowly with the charge symbol present. At that time the charging begins to take much longer even when tab is not in use and screen is off. After a week charging stops with that cable.
    Then I'll plug in a new cable and all is fine for a while .......... then the problem starts over again. The cables that lasted the longest were (I'm sorry to say) the OEM Samsung cables. Problem with them is they are too short if you want to charge while working on the table. Now, I've gone through ~6 aftermarket cables (6 and 10ft) and the Samsung continue to charge fine ......... although one is beginning to slow.
    When the cable begin to charge slowly it is evident that there is a looser fit between the cable Micro-USB plug and the charging port. Samsungs have retained a snug fit.
    In examining the port on the tab it seems the opening in the frame for the charging port may be a tad smaller than some of the cables plugs. My speculation is the after market cables are manufactured with a metal too soft for the opening so after a while it begins to get misshapen or just flattened to the point that the plug either can't make contact or becomes an intermittent contact.
    That being said, is there a video or written directions on how to remove the back of a Note Pro 12.2? I still would like to check the battery connections
    04-09-2016 05:00 PM
  5. desavannah blob's Avatar
    I let mine charge for the whole day and night without using it and it only went to about 33% and I had to keep taking the charger out and putting it in again because it kept showing the x in the charge box and even then it would not get rid of the x, so I charged it again and now it's on 1% and will not charge
    05-29-2016 10:53 PM
  6. bonsaimac's Avatar
    DENNISOS2 - I agree with you entirely
    I'm on my 3rd Galaxy Note Pro 12.2. All have had the same problem. Over time, the tablet USB 3.0 port seems to make erratic/poor/no contact. Always, I am able to get reasonable charging by keeping slight tension on the charging cord pulling it very gently toward me as I face the sceen. (to further complicate this, I lose charging even under this condition if the screen times out, but easily resumes if I re insert the cable and apply the same upward pressure) CRAZY. i get 100% charge during night by resting the male end of the cable on a pen so that the usb connection is pushed upward by the weight of the tablet while fully inserted into the 3.0 port on the tablet.
    Have you found a fix for this electrical contact problem??
    There are many confounding variables with the charging issue as noted in other threads. I also have had a slow/inadequate charging problem with OEM chargers/cables resolved by doing the power/volume high button system reset. I also started having problems with the first android OS upgrade. So there are software issues as well as hardware issues.
    But there is clearly a mechanical/contact problem with the 12.2 Note Pro usb 3.0 port over time. I think this is the most vulnerable part of all portable devices due to inevitable tugging on cables attached to the devices. It is unfortunate that Samsung stopped production of them, guaranteeing that the fixes are up to us end users. Any SUCCESSFUL suggestions by anyone would be most appreciated.
    08-14-2016 12:19 AM
  7. muzzy996's Avatar
    I have used my tablet daily for the past 26 months topping up charges and charging overnight using both the stock cable and aftermarket USB 2.0 ones and I have no problems with the port being damaged or worn. Heck, I wish I could get as much "action" as my Note Pro gets lol. Obviously YMMV. In any case a replacement charging port is probably available, I saw one on Amazon for under $20, and there are videos on battery replacement (search YouTube for newpower99 note pro ) during which one can see that the power port assembly is accessible after taking off the back cover.
    08-14-2016 09:46 AM
  8. DennisOS2's Avatar
    Thanks. I will look up the videos.
    08-26-2016 05:03 PM
  9. srjacob99's Avatar
    If anyone is looking at this thread, I had the same problem. The internal charging port wears out, and has to be replaced. Be aware, that the port and cable is different for the Verizon version and the wifi version of this tablet. All the chinese replacement cables I found are for the wifi version and if you use them on the Verizon version, the tablet won't recognize the SIM card.
    I had to order the proper port and cable from Samsung. They send the right one, but it was around $38.
    Steve
    06-17-2017 03:10 PM
  10. Beut's Avatar
    1- Samsung parts are made from China, so there is no different. Most US sellers are middle men as they bought it from China, popular site is Ali Express.
    2- The charging port flex is the same in wifi or LTE, Note Pro or Tab Pro: SM-T900,SM-P900, SM-P905, SM-P907. I have all of these models and most internal parts are identical, for example, I can install a SM-P900 (Wifi) or SM-T900 (Tab Pro) motherboard and rear camera to a LTE Verizon tablet without problem ( LTE rear camera doesn't work with Wifi Note Pro or Tab Pro mainboard ). I can modify and change from LTE to Wifi version or vice versa with ease as no much differences in parts.
    3- USB 3 cable must be the right one, others look identical but for phones, only draw 1 Amp, the correct one should draw 1.7 Amps. Parts from Samsung are overpriced, like the S-Pen is over $20 but I can get it from Ali Express for only $2.50/each, the same one with Samsung logo.
    This is an example of a S Pen used in P900, P905 ,P907, P600, P605, P607, from a Chinese seller
    New A++ +Touch Stylus S Pen For Samsung Galaxy Note 10.1" 2014 P600 P601 P605 | eBay
    07-01-2017 02:01 AM
35 12
  1. Note Pro 12.2: Just picked one up last night have a few questions!
    By iLLusive in forum Samsung Galaxy Note Pro 12.2
    Last Post: 04-14-2014, 08:19 PM
  2. Galaxy S5: I made a huge mistake today...
    By thegrants82 in forum Samsung Galaxy S5
    Last Post: 04-14-2014, 04:53 AM
  3. Galaxy S5: Worth it to upgrade from Galaxy S3 ?
    By MeNTaIPaTleNT in forum Samsung Galaxy S5
    Last Post: 04-13-2014, 06:29 AM
  4. Replies: 5
    Last Post: 04-12-2014, 07:11 PM
  5. How To get Internet Access On My Galaxy Gear.
    By Nika Lomtadze in forum Samsung Galaxy Gear
    Last Post: 04-12-2014, 01:41 PM
