1. Jennifer Emes's Avatar
    My Samsung note pro 12 will constantly stop a game I am playing (multiple different games by different brands, all out of Google play) and go back to the home screen for no reason that I can figure out. It's gotten past the annoying stage and I would love to be able to do something to fix this problem. Also constantly (every 10 min or so) blanks out and "resets" whatever book I am reading, no matter the reader I am using (nook reader, google books, or 3rd party readers downloaded off google play store). What could be causing this?????
    Thanks,
    Jen
    11-23-2014 10:40 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try booting into Safe Mode, which prevents all 3rd party apps from starting up. Then start opening apps one by one, and see if you get the same problem. If not, then some app you installed is probably causing the conflict or instability. It can be challenging to figure out which one, though. Safe Mode Samsung Galaxy Note Pro | Verizon Wireless
    You could also try wiping the system cache partition, which won't erase any personal data: Wipe Cache Partition Samsung Galaxy Note Pro | Verizon Wireless
    11-24-2014 01:46 AM
  1. AT&T NOTE 3 just got my 4.4.4 update!
    By bobbysnj in forum AT&T Samsung Galaxy Note 3
    Last Post: 12-13-2014, 05:43 PM
  2. Why is everything stopping and why is status custom?
    By david7668 in forum Samsung Galaxy S4
    Last Post: 11-23-2014, 09:34 PM
  3. Note pro issue
    By elvyb in forum Samsung Galaxy Note Pro 12.2
    Last Post: 11-23-2014, 05:12 PM
  4. Most info here or Note 4 thread
    By glidersgalore in forum Samsung Galaxy Note Edge
    Last Post: 11-23-2014, 10:56 AM
  5. Samsung knox?
    By joedm126 in forum Samsung Galaxy Note 3
    Last Post: 11-23-2014, 09:48 AM
