1. PlanetPluto7's Avatar
    Anyone know of a way to sync my S-notes or Action Memo between my Note 3 and the 12.2? Would be very helpful.
    12-06-2014 05:38 PM
  2. kajira81's Avatar
    If you sign into your samsung account on both devices and have them both synced to it they should update on both.
    I use evernote as well and sync s note with that and that did the trick too it creates an s note folder in evernote which is nice.
    PlanetPluto7 likes this.
    12-09-2014 05:04 AM
  3. PlanetPluto7's Avatar
    Thank You very much!
    12-10-2014 06:37 PM
  1. Make Note 4 feel like Nexus 6
    By benliverpool08 in forum Samsung Galaxy Note 4
    Last Post: 12-08-2014, 12:19 AM
  2. Kitkat- Not allowing apps to install from sdcard!!
    By suryaschwarzennegger in forum Samsung Galaxy Note 4
    Last Post: 12-06-2014, 07:30 PM
