1. Grimgrak's Avatar
    I find that when I open a file and load say a 1000page book the first jump in pages takes like 3 minutes or something crazy then all of a sudden something magical happens.... I can scroll as fast as i want in between pages without it lagging at all! Normally when i just try to scroll fast i can do 3-4 pages then the next ones start showing up blank... How does the loading work so i can have smooth scrolling is there a progress bar to know when that is "enabled" and ready to go?
    12-20-2014 07:02 PM
  2. muzzy996's Avatar
    Sounds normal lol. It takes a while to cache the document. I don't know if you can change that behavior of the application but maybe there are other PDF readers that perform better?
    Sent from my SM-P900 using Tapatalk
    12-20-2014 08:59 PM
  3. Traylaw's Avatar
    Try another PDF reader, I use Ez-PDF over Adobe. There are a couple of readers on Google Play that are better then Adobe.
    12-26-2014 04:50 PM
  4. PortablePete's Avatar
    X2 on ezpdf reader
    12-27-2014 08:00 AM
  1. $149 on amazon, note 4
    By whyst in forum Samsung Galaxy Note 4
    Last Post: 12-21-2014, 08:20 PM
  2. Replies: 1
    Last Post: 12-21-2014, 02:42 AM
  3. Pen window once maximized how to reshrink
    By Grimgrak in forum Samsung Galaxy Note Pro 12.2
    Last Post: 12-20-2014, 08:56 PM
  4. How to add additional apps in the 'share via' option?
    By joydevivre in forum Samsung Galaxy Note 4
    Last Post: 12-20-2014, 04:29 PM
  5. Replies: 1
    Last Post: 12-20-2014, 03:44 PM
