1. fdisker2000's Avatar
    Is the Snapdragon processor in the LTE version of the note pro 12.2 worth the $100 premium over the Cortex(exynos) in the WiFi version? I wouldn't be using the LTE in the LTE version, I just want to know if performance, reliability, etc. is better.
    03-05-2015 09:46 PM
  2. Rukbat's Avatar
    From the specs, I wouldn't think there'd be much difference in performance, but there should be some side-by-side comparisons on the web.
    03-05-2015 11:06 PM
  3. ehosey2's Avatar
    From the research I did leading up to a purchase of a Note Pro 12.2 for my wife I ended up getting her the LTE version with the Snapdragon 800 processor. Those video reviews indicated while mostly similar speed performance the mult-tasking performance such as using multi-window and running several applications produced bits of lag on occasion with the Exynos version. Watching video reviews also implied that the Snapdragon 800 version charges faster than the Exynos version. I have played with my wifes AT&T Note Pro 12.2 and it is a great tablet that I will most likely buy one myself.... the Snapdragon 800 version.
    03-06-2015 03:51 AM
  4. rogerwalker22's Avatar
    After doing research myself on the web and Youtube I also went with the Snapdragon 800 Verizon LTE version. I already had Verizon so I just added to the plan and i've loved it since day 1.
    03-09-2015 03:03 PM
  1. MMS over Wifi
    By reg0303 in forum LG G2
    Last Post: 03-06-2015, 04:55 PM
  2. Why has my wifi stopped working after using KIES to update?
    Last Post: 03-05-2015, 11:13 PM
  3. Replies: 1
    Last Post: 03-05-2015, 05:51 PM
  4. Replies: 1
    Last Post: 03-05-2015, 05:05 PM
  5. Replies: 1
    Last Post: 03-05-2015, 04:53 PM
