1. Grimgrak's Avatar
    Worst part is you can't disable or get rid of it! Now my beloved SNP wont last me the whole day and is about ready to die by lunch!
    03-20-2015 07:13 PM
  2. Rukbat's Avatar
    Turn the tab off. Boot into recovery. Clear the system cache (NOT factory reset). See if that helps.
    03-20-2015 07:17 PM
  3. Grimgrak's Avatar
    How do u boot into recovery?
    03-20-2015 09:39 PM
  4. Rukbat's Avatar
    From How to Enter Samsung Galaxy Note Pro 12.2 Recovery Mode
    Power off. Boot in recovery mode by pressing and holding Volume Up, Power Button and Home Button at the same time. Release all buttons when the Samsung Galaxy Note Pro 12.2 screen flickers and in a few seconds the Recovery screen will appear.
    03-20-2015 10:18 PM
  5. muzzy996's Avatar
    I had this happen to me recently when I copied a bunch of huge PDF files to my microSD card. I ended up not needing them so I took them off but the tablet was definitely having trouble indexing them.
    03-21-2015 06:23 PM
  1. Replies: 4
    Last Post: 04-08-2015, 07:28 PM
  2. Replies: 2
    Last Post: 03-20-2015, 11:20 PM
  3. Why did my Android phone block?
    Last Post: 03-20-2015, 06:54 PM
  4. How to root my Galaxy S5?
    Last Post: 03-20-2015, 06:41 PM
  5. whats the satllite icon in my icon teay
    Last Post: 03-20-2015, 06:21 PM
