1. mcdobson's Avatar
    Hello guys, i am hoping that you can help me because i don't know where else to turn. I purchased a Verizon note pro 12.2. I was using it and on for about two weeks until i got my surface 3. Two days ago i went to use it and it wouldnt turn on. I assumed it was the battery so i put it on the original charger for about an hour and attempted to turn it on. It booted to the Verizon logo then flickered off. I put it back on the charger overnight thinking that would fix the problem. When i attempted to turn it back on it loaded to the Samsung splash screen and then turned off again. When i plugged in the charger once again the grey battery icon came up saying the battery was 100%. Even with the battery saying it was 100% it still wont turn past the splash screen. This only happens when it connect to the charger. it doesn't do anything at all if it is not plugged in. I have taken the battery out and reconnected it... still nothing. Looking at other post i assumed it was a software issue so i tried to sideload a stock version (Cant use odin because the tablet cant even boot into odin mode) of P905VVRUANK1 which is what the tablet was running. I got the error footer is wrong security authentication failure. I dont know what to do. Please help!!
    10-03-2015 01:35 PM
  2. treetopsranch's Avatar
    Return it for a refund or another tablet.
    10-03-2015 06:24 PM
  3. Grimgrak's Avatar
    I take it this is not a wifi model?
    10-03-2015 06:31 PM
  4. Beut's Avatar
    You have a cracked battery connector, re solder will fix your problem
    This is the one needed to re solder, it takes only under 5 minutes.
    And this one already re soldered with more solders added to secure all six pins
    mcdobson likes this.
    10-03-2015 06:42 PM
  5. mcdobson's Avatar
    no its not... its 4g lte
    10-03-2015 06:45 PM
  6. mcdobson's Avatar
    could I possibly take a picture so you can see...
    10-03-2015 06:46 PM
  7. Beut's Avatar
    This is not software problem based on what you said : "It doesn't do anything except plugged in".
    Believe me or not, it's up to you. I see many problems like this from a loose or cracked battery connector. Swap another battery won't help anything if the connector is cracked.
    10-03-2015 07:16 PM
  8. mcdobson's Avatar
    Thank you so much for your help... took the time to re-look at the connector thoroughly and you are right. I pushed the connector firmly with the back still off and it finally booted with and without being connected to the charger. I don't know how to solder well. is there any way i can push it back in place with electrical tape or maybe gorilla glue.
    10-03-2015 07:25 PM
  9. ccpopham's Avatar
    No tape will allow for wiggling and possibly arc. Gorilla glue will not work either. It has to be solid metal to metal with solder.
    10-04-2015 07:27 AM
  10. Beut's Avatar
    Don't use glue as it doesn't work with solder joints. Bring it to a repair shop, they can help you with little charge as they're told what to do and it takes only under 5 minutes.
    You just need to open the back cover, disconnect battery and they can re solder from the top without remove the main board.
    10-04-2015 11:54 AM
  1. Why won't my phone ringer work?
    Last Post: 01-18-2016, 12:50 PM
  2. Qi wireless charger not charging Cat S50
    By Elma van Zyl1 in forum Ask a Question
    Last Post: 10-04-2015, 08:20 AM
  3. Why Wifi turns off when I unlock screen?
    By skyrail in forum Samsung Galaxy S4
    Last Post: 10-03-2015, 11:20 PM
  4. Replies: 1
    Last Post: 10-03-2015, 11:13 PM
  5. Note Pro 12.2 wont turn on, not rooted
    Last Post: 10-03-2015, 11:12 PM
