1. AC Question's Avatar
    I had flickering screen last month or so than the charger messages to use original cord. I AM. Slow charging too. Than it starting shutting down out of the blue when it was at 50-70% crazy. Now last time I used it 3 days ago it was at 70% and I shut it off now it won't turn back on
    02-08-2016 10:29 PM
  2. belodion's Avatar
    That may need repairer attention.
    02-09-2016 03:33 AM
  3. AlphaTango414's Avatar
    You may need a new battery.
    02-09-2016 05:39 AM
  4. Beut's Avatar
    Remove the back cover, pressing on your battery connector with your finger while power on. If you can turn on this way , make sure charging it for few hours, then you only need to get the battery connector re soldered by someone who know how to solder or a repair shop .
    Read the threat " flickering screen " for more information, but you only need the last few pages, other pages have no correct or guessing information.
    I guarantee 99% that you have a cracked battery connector and 1% battery has loose connections ( the white connector with 6 wires ).Most people think the battery is bad but actually it works fine, only the white connector needs to be fixed. I had one battery someone threw away as it's not charging, but I fixed the white connector, then it works normal again,
    02-09-2016 06:35 PM
  1. No correct notifications on lock screen. on P8
    By mhs_m0nk3y in forum Huawei P8
    Last Post: 03-02-2016, 05:21 PM
  2. Replies: 3
    Last Post: 02-09-2016, 12:47 PM
  3. Replies: 1
    Last Post: 02-08-2016, 10:29 PM
  4. My phone keeps freezing
    By in forum Ask a Question
    Last Post: 02-08-2016, 10:18 PM
  5. Replies: 1
    Last Post: 02-08-2016, 10:11 PM
