1. Martin Cracknell's Avatar
    Hi All,
    Would you know if it is possible to run Android 6.0.1 on a Samsung Tab Pro 12.2?
    It is currently running Android 4.4.2.
    As certain features and apps are unavailable on the tablet's current OS, it is kind of restricting...
    Any assistance would be greatly appreciated.
    Thanks,
    Martin
    06-29-2016 07:22 AM
  2. muzzy996's Avatar
    Tab Pro or NOTE Pro?
    Assuming you mean Note since you're here in a Note Pro specific forum - as of now there is no variant of the Note Pro that has 6.0.
    What is the model number of your device? Lollipop has been out for a while for several variants of the Note Pro.
    06-29-2016 11:24 AM
  3. Lyson Phiri's Avatar
    My model is sm-p905. can it run on OS 6.0.1
    06-30-2016 08:18 AM
  4. muzzy996's Avatar
    Nope, as noted earlier there are no variants of the Note Pro that I know of that have 6.0.
    See here:
    Android 6.0 Marshmallow update roundup
    Note Pro 12.2 is not listed at all.
    06-30-2016 01:39 PM
  5. madaudio's Avatar
    To both posters wanting to run Android 6, I suspect your only option would be to root your tablets. Then your options are wide open. Even the new android N which I believe is now only a few weeks away.
    But don't think, because I have put this forward, that you can ask me how!!!! I have never rooted any of my android phones or tablets, just read about the process in this and other forums. Suggest you do a search through the forums on the terms root or rooting.
    07-09-2016 07:47 PM
  6. muzzy996's Avatar
    Yeah there are a couple of 6.0 based custom ROMs based either on cyanogenmod or AOSP for a couple of variants of the Note Pro. Built in S-pen functions won't be there but the pen will work fine and applications can be loaded to use it. Personally I don't see the point of owning a Note product and running a ROM that isn't Touchwiz based but I can appreciate that some may not have a need for any of the built in functionality.
    07-09-2016 08:20 PM
  7. cganesh's Avatar
    Martin
    There was an update for the note pro 12.2 that took it up to 5. (don't remember the exact numbers after the decimal) some time back. You can download it from the Samsung website. I use smart switch software from Samsung to backup and download updates to both my 12.2 and my Note 4. Has been very stable and seemed to work faster after that software update. Have held back even updating my Note 4 to 6 due to issues others I had.
    09-03-2016 11:22 AM
  1. Cannot send contact details via sms on nexus 5
    Last Post: 07-05-2016, 08:13 AM
  2. Lack of notification sound on email when it updates
    Last Post: 06-29-2016, 07:17 AM
  3. Replies: 1
    Last Post: 06-29-2016, 06:42 AM
  4. The Possibilities to Run Multiple ADB Instances in the same system
    By Karthi Keyan19 in forum Ask a Question
    Last Post: 06-29-2016, 06:28 AM
  5. In My spice Android Google play services missing
    By Rishal Poonia in forum Ask a Question
    Last Post: 06-29-2016, 06:24 AM
