1. Walter Turns's Avatar
    I have been using my note 12.2 since January for work. At meeting I would have OneNote and a PDF document open, taking notes in Onenote. This morning at a meeting when i opened the menu on the right to open OneNote and Xodo OneNote was not there. I looked in edit and it was not there either.
    I have been on vacation a couple of weeks so have not used it, has something changed can I get OneNote back?
    I had to use lecture notes, I imported them into OneNote which worked fine on my PC, but in the Android OneNote app is nothing but a black square. I have been using OneNote for a couple of years and really want to continue using it, any suggestions?
    07-12-2016 09:11 PM
  2. fatyank's Avatar
    Have you tried a restart on your device? That may get OneNote back. You also can go to Google Play Store and download One Note again. Your notes should be stored in One Drive cloud so you can sync them once you get the app to reappear on you tablet
    The Fatyank
    tube517 likes this.
    07-13-2016 09:13 AM
  3. tube517's Avatar
    One Note app was updated recently. Make sure you have the latest update
    07-13-2016 09:24 AM
  4. Walter Turns's Avatar
    Solved
    I tried turning off the tablet that did not work
    So I deleted and reinstalled the app it now works fine
    Thanks everyone for the help
    07-13-2016 09:54 PM
  5. Walter Turns's Avatar
    I guess I spoke to soon, it was there when I reinstalled it, but when I tried it it would not work as split screen. I restarted the tablet thinking that may help and now it is gone from the split screen menu again, any thoughts
    07-14-2016 07:24 AM
  6. jmd2119's Avatar
    I am curious to know if you found a resolution. I returned to grad school to find that I could no longer use split screen in OneNote on my Note Pro 12.2, and have had to switch to another app. My situation was exactly as yours. OneNote was no longer in the multiscreen sidebar, so I uninstalled and reinstalled. It showed up, but still reverts to full screen.
    09-05-2016 06:22 AM
  7. Walter Turns's Avatar
    No I have not found a solution, but have not given up, at least yet.
    09-05-2016 07:40 PM
  8. jmd2119's Avatar
    My OneNote updated this morning, and I am once again able to do split screen. It appears that the problem has been fixed!
    09-07-2016 07:52 AM
  9. Walter Turns's Avatar
    Thanks jmd2119 I just think tried it and it works at least for now, thanks again
    09-07-2016 05:58 PM
  1. Galaxy S5 shuts down and goes into boot loop randomly
    By wec123 in forum Samsung Galaxy S5
    Last Post: 12-03-2018, 11:22 AM
  2. Replies: 16
    Last Post: 07-15-2016, 02:44 PM
  3. Replies: 2
    Last Post: 07-14-2016, 04:19 AM
  4. Gear S2 and fitbit
    By johnmcc0710 in forum Samsung Gear S2
    Last Post: 07-13-2016, 01:29 AM
  5. Replies: 0
    Last Post: 07-12-2016, 08:33 PM
