1. AC Question's Avatar
    I have experienced this problem since I opened the box.
    There are occasions in which I have enter and reenter my sign on password multiple times before the tablet will proceed to the "desk top." Here's the pattern that I've learned.
    Assume the table needs charged and is on the charger:
    Attempt to enter password.
    Fail. - "Try again"
    This is repeated multiple times. I've even got close to "factory reset" because I've had to enter the password so many times.
    Now, assume I've unplugged the charger OR has not been plugged in to the charger since the last sign-on/sign-off:
    Success.
    The device proceeds to the "desk top."
    This sequence occurs almost 100% of the time.
    07-15-2016 09:43 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! When it's charging, do you notice that the touchscreen registers inaccurate touches elsewhere (like when you're tapping on an icon)? If so, it's possible the charging itself is interfering with the screen. That could be related to inadequate or faulty shielding of the charging components, leading to disrupted touchscreen function due to the electromagnetic field that's generated. If this is the case, the device would probably need a repair shop. Is it still under warranty?
    07-15-2016 05:30 PM
  3. 1963_Lloyd_1963's Avatar
    It is under warranty.
    When the device is off, I simply see the charging/battery icon in the middle of the screen
    07-29-2016 09:57 AM
  4. 1963_Lloyd_1963's Avatar
    What about this situation?
    Success.
    07-29-2016 11:06 AM
  1. Why doesn't my Galaxy S4 identify my charger most of the time?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 07-16-2016, 09:38 AM
  2. Brand new and won't turn on
    By Cwey55 in forum Huawei Watch
    Last Post: 07-15-2016, 07:29 PM
  3. Replies: 1
    Last Post: 07-15-2016, 09:58 AM
  4. How do I access pictures stored on my Samsung cloud via my laptop?
    Last Post: 07-15-2016, 09:18 AM
  5. Replies: 1
    Last Post: 07-15-2016, 08:48 AM
