Samsung note pro 12.2 sm-907A Sim not recognized error
A
AC Question
Had system for awhile and decided to add AT&Texas Sim at store. Tried 3 Sims and keeps saying no sim. Android 442. Looked for firmware or LA updates but to no avail. Thoughts?
Thanks in advance.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,541
4,675
113
Re: Samsung note pro 12.2 sm-pizza Sim not recognized error
Welcome to Android Central! Sorry, but what's the exact model number? Pretty sure Samsung doesn't have a device with the model number SM-pizza. :p
BigDaveM
Not sure which is worse; auto correction or my not proof reading. My apologies.
It is a sm-p907a. Through the device I cannot get the OS beyond 4.4.2 and cannot find any firmware updates. Under settings "More Networks" Mobile Networks is greyed out.
Javier P
Ambassador
Feb 21, 2014
19,480
3
Mod note. Haha, no worries. I edited the title and moved the thread to the Note Pro 12.2 forum, where it'll be easier getting feedback from other owners.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,541
4,675
113
Have you ever successfully used a SIM card in this device? Or did you get it used or refurbished from somewhere? It may be that the SIM reader is faulty, or there could be debris in there. Try blowing it out with a can of compressed air.
BigDaveM
Had system several years but first time trying a sim. Tried compressed air with no success.
Beut
511
For the SIM card slot, it's not expensive and easy to replace. All you need is remove the back cover, then take out 1 screw to take out the SIM and SD flex cable.
New Sim Card Slot Holder Flex Cable Board for Samsung Galaxy Note Pro 12 2 P905 | eBay
If you want to update to Lollipop, download these 2 files and use your SD card to update
http://forums.androidcentral.com/sa...roblems-np12-2-blue-screen-2.html#post4963702
Remember to back up your files as after update, it automatically reset your tablet
Chelsea rae
