1. azzicles's Avatar
    Hi guys,
    I purchased a Note Pro in pretty damn good condition on the outside, and perfect on the inside. (So no liquid damage).
    The fault is that it's dead. I can't get any response out of the display, speakers, vibrator, notification LED, etc.
    What I've done:
    - Re-soldered battery connector and verified pin contacts.
    - Every vol+power+home combo that exists.
    - Re-seat all connectors and ribbon cables and verify lower LCD connector.
    The only life it has is the chip that's under the can that's closest to the SD card gets warm (only when connected to charger (5V/2A)) and the battery voltage slowly increases when read by my multimeter. When I purchased the tablet I think the battery voltage was around 2.6v. I trickle charged it up to currently 3.75v. Still no life. 2.6v is very low for li-ion but I don't want to spend money on a battery if there's another fault. I have no bench supply.
    One more thing I noticed. There's two blue wires coming from the battery. One of them measured between ground gave me some stable voltage, like 3.5mv or something like that. The other blue wire is all over the place. I can't get a reading from it, and I was measuring from the white connector so I know I was making contact. I'm not sure if this could be a fault stopping the tablet booting?
    Is there any test points on the PCB I can check to diagnose a fault location?
    Anyway, has anyone got any ideas?
    I've tried everything.
    Thanks!
    12-06-2016 01:30 AM
  2. azzicles's Avatar
    Anyone?
    I'm trying to power it from bench supply now (via battery in) at 3.8v. When I turn the power on it draws nothing. If I hold power for one second as normal it begins drawing 168ma and about one or two seconds later it drops to 148ma and is dead.
    Any repair techs?
    12-09-2016 02:35 AM
  3. Beut's Avatar
    A dead tablet with unknown history is impossible to troubleshoot without spare parts such as working mainboard, USB port flex, and full charged battery.
    - A working mainboard of Tab Pro or Note Pro can tell if the display is working.
    - A full charged battery can turn on a tablet with a defective charging circuit.
    - A working USB charging port can turn on a tablet with bad USB port ( lucky case ).
    These are just few examples to troubleshoot a dead tablet with unknown history.
    But in your case, I can guess the mainboard is dead. A dead display will have no images but you can hear the sound or the light of two buttons when the tablet is ON.
    How much you paid for this Note Pro ? If it's under $150, then you can try to fix it
    With a working mainboard and battery I can troubleshoot quickly the source of problem from a dead tablet.
    12-09-2016 06:12 PM
  4. azzicles's Avatar
    Thanks for your reply,
    I paid AUD $50.
    I've removed the battery and I'm supplying the battery input terminals from a bench supply at 3.8v.
    When powered on (Holding power for 1 second) it just draws ~150ma and does nothing. No sound, vibration or button LED's.
    I wish I had another SM-P9XX to troubleshoot but I don't
    Would you know where I could find the P905 service manual? I've found P900 and P901 SM but the board layout is different on the P905 vs P900/1 so I can't locate and test components / check voltage around cpu, etc since I don't know where to probe.
    12-13-2016 09:19 PM
  5. Beut's Avatar
    I don't think practically troubleshoot component levels of Samsung mainboard as you cannot find components in the market, except swapping from another working board. Then most people just rather change the maiboard than try to repair it.
    Try to buy any SM-P900 Wifi or LTE mainboard, they will work with the LCD assemly.
    I bought this one just for taking the mainboard and other parts
    Samsung Galaxy Note Pro 12.2 SM-P907A WiFi 4G LTE AT&T 32GB Black Unlocked AS IS 887276975283 | eBay
    12-14-2016 08:23 PM
  1. Samsung Galaxy Note 8 Release Date
    By James Falconer in forum Samsung Galaxy Note 8
    Last Post: 01-23-2017, 01:14 PM
  2. WiFi Issue with Verizon Note 5
    By sforsyth01 in forum Samsung Galaxy Note 5
    Last Post: 01-08-2017, 12:08 PM
  3. Has anyone seen the following with Galaxy Note 4
    By rmholler in forum Samsung Galaxy Note 4
    Last Post: 12-06-2016, 06:43 PM
  4. How to start Galaxy note 8.0 in Safemode (GT-N5100)
    Last Post: 12-06-2016, 12:47 AM
  5. Does a hard reset on the note 7 reverse the battery nerf?
    Last Post: 12-05-2016, 05:40 PM
