1. DennisOS2's Avatar
    I hope this isn't a stupid question, but I don't know how to open the Air Command after you've removed the stylus for another use. Say you clipped a portion of the he screen and now you wish to screen write. You don't have to replace the stylus then remove again from its holder in order to bring up the Air command, do you? What has to happen to bring up the Air Command.
    Thanks
    02-14-2017 10:08 AM
  2. muzzy996's Avatar
    I use the button on the pen itself. Have to enable the feature:
    Settings - Controls - S Pen
    Air Command - "When you press the pen button while hovering your pen over the screen, the air command features will appear."
    02-14-2017 01:03 PM
  3. DennisOS2's Avatar
    Yup, that works😃 Too easy. Thanks.
    03-08-2017 06:51 PM
  1. Pre-ordering S8 Plus Online with Verizon
    By WylenNeil in forum Samsung Galaxy S8 & S8+
    Last Post: 03-27-2017, 01:02 PM
  2. Replies: 2
    Last Post: 02-21-2017, 09:21 AM
  3. How can I spoof an sms with specific number?
    Last Post: 02-15-2017, 09:05 AM
  4. Replies: 0
    Last Post: 02-14-2017, 09:05 AM
  5. Pre-ordering S8 Plus Online with Verizon
    Last Post: 02-14-2017, 08:30 AM
