1. DennisOS2's Avatar
    Beut has made it quite clear in a number of threads that anything having to do with battery charge on the 12.2 is likely the solder joints on the battery connector. The solder joints having cracks. It sounds like an easy fix for someone that has the equipment, but difficult for the rest of us.
    To date has anyone had their 12.2 solder joints repaired (re-soldered)? If there are some out there that have had this problem fixed by re-soldering can you give the rest of us some info about what kind of place did the repair. If it was an authorized Samsung repair facility could you share contact info? And what did you have to tell them to have this repair done correctly?
    I have been all around the Philly area and haven't found anyone that does fine soldering.
    Thanks
    03-22-2017 10:10 AM
  2. treetopsranch's Avatar
    Didn't Beut say he would fix it for you. I seem to remember reading it in one of his posts. I think he also said no guarantees and you would pay postage both ways. Maybe you could send him a private message.
    03-22-2017 12:43 PM
  3. DennisOS2's Avatar
    Yup, I did reach out to him but can't remember getting a reply.
    03-23-2017 04:58 PM
  4. SHIVA77's Avatar
    guys, this is an important thread. I have a 3 year old Note Pro, the battery doesn't perform below 70% and drains fast. I contacted Samsung, they gave me a local number, I called the number and they said they don't fix tablets. That place gave me a number in PA, called those a few times never heard back nor anyone ever picked up the phone. My local VZW store gave a local repair shop, called those and they said they can't work on Note Pro!!!!
    So, I love my tablet and yes I can pick up a new tablet, but love to be able to make it run on battery again.
    Planning to order a battery from Amazon and not sure ultimately if it will solve my issue.
    https://www.amazon.com/gp/product/B0...cUvbUpU5723431
    Any thoughts?
    03-23-2017 11:20 PM
  5. DennisOS2's Avatar
    https://www.amazon.com/gp/product/B0...cUvbUpU5728473
    Any thoughts?
    Given the issues discussed in this forum IMHO the battery will not necessarily fix the problem. Beut has been insistent that it is a cracked solder joint(s) where the battery charging connector plugs into the MB and that seems perfectly reasonable. I hoped we would have gotten numerous replies from people having the soldering fixed. In looking on YouTube there are no how-to videos on re-soldering those joints. One showed how the owner actually soldered the six wires from the connector directly to the MB. Seemed a bit drastic, but it worked. There's likely a ton of 12.2's sitting in drawers right now.
    03-27-2017 10:35 PM
  6. Beut's Avatar
    I did reply on your private message but may be you did not read it.
    Send it to me, problem may be solved.
    This lady had a more serious problem than yours, but the same defects of battery connectors
    http://forums.androidcentral.com/sam...ache-wipe.html
    03-28-2017 07:15 PM
  7. Beut's Avatar
    Professionals do it just under 5 minutes for this simple rework.
    03-28-2017 10:14 PM
  1. Battery Drain, Note 4 Running Hot After Verizon Update
    By gathome in forum Samsung Galaxy Note 4
    Last Post: 04-20-2017, 07:17 AM
  2. why my driod turbo 2 battery wont charge
    Last Post: 03-22-2017, 01:43 PM
  3. How can i fix this problem
    Last Post: 03-22-2017, 09:25 AM
  4. Note 5: battery drain issuse after unroot
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 03-22-2017, 08:31 AM
  5. New Battery
    Last Post: 03-22-2017, 06:39 AM
