1. andyhamish's Avatar
    well after reading some posts on a small part of the forum ...i am a bit confused.
    my 3 yr old note pro stopped working. a local 'tech person' suggested possibly battery has failed. so, i have found i can buy a replacement. please, how can i tell if it is the battery and not some other issue. battery usage has always been good and the only time i have ever had a flickering screen(as i assume is the same as many have referred to) was a couple of times over a couple of days prior to it not turning on again.
    06-20-2017 03:29 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! There's no way to tell unless you open up the device and either try a new battery or test the voltage of the current one.
    06-20-2017 11:50 AM
  3. andyhamish's Avatar
    thank you..... looks like i buy a battery and hope it works.
    if not, might there any way to recover info from the 'drive' or whatever you call it in tablets, ....
    06-26-2017 05:03 AM
  4. andyhamish's Avatar
    also....... are there any generic brands of batteries to suit my note pro or do i need to buy a samsung battery
    06-26-2017 05:05 AM
  5. B. Diddy's Avatar
    If a new battery doesn't help, then it'd be difficult to recover data from internal storage -- you'd have to look into a forensic data recovery specialist, which could cost a lot of money.
    It's hard to comment on 3rd party batteries, since the more generic they are, the worse the quality control may be (in general). Anker and Seidio are two well-known and trusted battery makers, but I'm not sure if they make internal batteries for your tablet. OEM is always best, if you can find it.
    06-27-2017 03:33 PM
  6. SHIVA77's Avatar
    NOTE PRO 12.2 BATTERY
    Get this one. I have it and works great so far.
    "Powerforlaptop Internal Battery For Samsung Galaxy Note Pro 12.2" WiFi P900 P901 P905 T900 T905 SM-P907AZKAATT SM-T900 SM-T905 Tablets T9500 / T9500C / T9500E with opening repair tool kit"
    https://www.amazon.com/gp/product/B01KO429G4
    B. Diddy likes this.
    06-28-2017 06:23 PM
  1. Replies: 1
    Last Post: 06-20-2017, 12:04 PM
  2. My lenovo k3 note takes 7-8 hrs to fully charged .
    Last Post: 06-20-2017, 12:01 PM
  3. Replies: 1
    Last Post: 06-20-2017, 11:59 AM
  4. Replies: 1
    Last Post: 06-20-2017, 11:58 AM
  5. Replies: 1
    Last Post: 06-20-2017, 11:54 AM
