1. Simcolala's Avatar
    I got a used Galaxy Note Pro 12.2 for over a month. Everything is OK and works perfectly. However, it will turn itself off when not in use after some time(in sleep mode). Sometimes it turns off when not in use after about 15 minutes, sometimes over 10 hours, sometimes it won't turn off. Fortunately, when I am using it, it works fine and will not turn off. I have tried resetting the device and taking off the book cover, it is still the same.
    It is a minor issue to me. I can turn it on again if I have to use it again. But I think a tablet should not turn itself off automatically even in sleep mode without any user's command just like my andriod phone won't turn itself off even in long hour sleep.
    Is there anything I can do to fix this issue?
    Marko Melih likes this.
    11-16-2017 12:40 PM
  2. Marko Melih's Avatar
    I bought a new battery, put it in and it started doing what you just described. After a few days I replaced it with an old one and now it's fine. So for me it is battery I bought off eBay.
    12-13-2017 09:32 AM
  1. Notification access turns off itself
    By Android Central Question in forum Samsung Gear S3
    Last Post: 12-30-2017, 07:35 AM
  2. S8+ volume automatically turning down when using headphones
    By SaraIsabellaNZ in forum Samsung Galaxy S8 & S8+
    Last Post: 11-21-2017, 12:30 PM
  3. No sound in some apps with Iconia one 10
    Last Post: 11-18-2017, 12:40 AM
  4. How can I add function like camscanner in android webview app
    Last Post: 11-16-2017, 03:28 PM
  5. How do I know if my Samsung Galaxy Note 5 is unlocked?
    Last Post: 11-16-2017, 12:06 PM
