1. Gomox's Avatar
    Hello everyone! My S-Note app, which comes pre-installed on the Galaxy Note Pro, has been working perfectly for the last few years. However, last week it suddenly stopped working. Opening it only causes a black screen. I'd love to uninstall and reinstall the app, but since it comes pre-installed I can only "disable" it, which doesn't help. I also tried rebooting the tablet of course. Any idea on how I can fix the app without having to reset the whole tablet? Many thanks
    02-15-2018 09:16 AM
  2. B. Diddy's Avatar
    Go to Settings>Apps, select S Note, and Clear Cache. If you don't have any crucial notes already saved and clearing the cache doesn't help, try also Clear Data.
    Gomox likes this.
    02-15-2018 04:56 PM
  3. Gomox's Avatar
    Wow, this worked perfectly! Why didn't I think of this earlier Thank you so much
    B. Diddy likes this.
    02-16-2018 08:21 AM
  1. Note FE New or Refurbished???
    By CoKain-Tremaine in forum General Help and How To
    Last Post: 02-13-2018, 03:33 PM
  2. My navigation stopped on my Android so it doesn't go back
    Last Post: 02-11-2018, 09:21 PM
  3. Galaxy S4 won't turn on
    Last Post: 02-11-2018, 09:17 PM
  4. YouTube TV does not work correctly
    By mgiff06 in forum Samsung Galaxy Note 8
    Last Post: 02-11-2018, 09:16 PM
  5. Wet Charging Port Warning Going On & Off
    By Joshua_Muldoon in forum Samsung Galaxy Note 8
    Last Post: 02-10-2018, 03:12 PM
