1. GR37's Avatar
    My beloved Samsung Note Pro 12.2 is freezing up on the startup Samsung logoand won't go any further.
    Have tried re-booting as well as holding the power & volume switches down together but to no avail.
    Any ideas?
    04-09-2018 06:08 AM
  2. treetopsranch's Avatar
    Sorry to hear that news. I guess I'm lucky, as I still use this tablet every day.
    One thing you could try, if you haven't already, is to plug it in to wall (Like you would charge the battery). Then turn it on. Post your results here so others may read it or have another suggestions if that didn't work.
    04-11-2018 12:49 PM
  3. DannoLINY's Avatar
    I can no longer update the apps on my SM-P900. I have cleared my memory for for the app store. Sometimes apps will download but not install, other times the apps will not even download. Any help would be greatly appreciated, thanks.
    08-22-2018 08:35 AM
  4. scott15851's Avatar
    Waiting for the S5 to come out but still want a bigger screen for work. Would a Note Pro 12.2 be okay if I could find one?
    I had a the original Note 2013 10.1 WiFi that is worthless and half the apps don't update and its stuck on like android 4.0
    06-19-2019 08:15 PM
  5. treetopsranch's Avatar
    Scott....It is a good tablet. IF you can find one cheap, go for it. Be aware that this tablet is no longer being supported. Lollipop is last update.
    06-24-2019 06:53 PM
  6. ehosey2's Avatar
    I still have my Note Pro 12.2 LTE and with the AT&T service. It is okay performance wise. YouTube is great, weather applications work fine, other applications here and there are okay but web browsing is too slow. I use it at work when I want to watch YouTube instead of my Note9. But when at home, I use my new Samsung Galaxy View2 with AT&T service. Despite the mid-range specs, this new tablet is a decent performer and sits at the right angle on my desk. It does everything really well. A lot of people don't get it but I understand it's purpose. It makes a great portable TV and multimedia device.
    06-25-2019 10:27 AM
  1. my note 5 is ghost typing And can't type text messages
    Last Post: 04-09-2018, 10:06 PM
  2. How's the fast charging of Samsung S9?
    Last Post: 04-09-2018, 03:41 AM
  3. Note 8 Sprint Connectivity Issues
    Last Post: 04-09-2018, 12:22 AM
  4. A Permanent Blue light on my Samsung Galaxy S8 Active came on, how do i fix it?
    By Android Central Question in forum Samsung Galaxy S8 Active
    Last Post: 04-08-2018, 10:08 PM
  5. Can you move the clock on the lock screen on the Samsung Galaxy s9 plus?
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 04-08-2018, 08:36 PM
