1. vhaporbrowns's Avatar
    Does anyone with a Samsung 4G Touch have the problem with frequent reboots without manual intertvention? If so have you figured out the cause/remedy?
    Thanks,
    sb
    Sent from my SPH-D710 using Android Central Forums
    07-13-2012 09:09 AM
  2. snazbk's Avatar
    I am having the same issue. When I called Sprint they told me to go to the local center to get it fixed or they will send me a replacement. When I went to the store they told me that everyone is having issues and to wait for an update. This is unacceptable because I cannot even make calls without the phone rebooting. This is very frustrating.
    07-23-2012 09:29 PM
