Below is the paste from my chat session:
Victoria: Hi, thank you for contacting Samsung Technical Support. How may I help you today?
Visitor: Hi Victoria
Victoria: Hi. How may I help you today?
Victoria: I don't mean to rush you, but I haven't had a response from you. Are we still connected in this chat?
Visitor: I recently bought Samsung Skyrocket cell phone. The phone seems to be having major issues in the bluetooth "department". To make the story short (and cut to the chase) I have tried the blueooth in 3 different vehicles (Acura, VW and Mazda), 4 different bluetooth
Visitor: (cont'd)
Victoria: I am sorry to hear that.
Visitor: Motorola, Plantronics and SAMSUNG. All of the seem to be having issues. Furthermore, there are multiple reports of same issues on multiple MJAOR Android forums and blogs (icluding ATT's own website, Androidcentral.com, XDA developers, etc.)
Victoria: I understand that you are unable to pair the phone with devices on cars, am I correct?
Visitor: no. I am able to pair (initially), but once you have to "reconnect" the phone via bluetooth, the phone hangs (i.e. bluetooth can't turn back on)
Visitor:
http://forums.androidcentral.com/galaxy-s-ii-skyrocket/133981-skyrocket-bluetooth-problems-help.html
Victoria: Thank you for confirming.
Visitor: i have a few more links to forums.
Visitor:
Bluetooth Issues? - xda-developers
Victoria: I apologize we do not have the access to browse third party websites.
Visitor: well, perhaps you could forward the links to your developers/management.
Visitor: I am almost 100% certin that the issue lies with Samsung hardware/software and NOT with bluetooth manufacturers.
Victoria: I'm sorry, I would like to inform you that there is no known issue with the phone as of now.
Victoria: However, I will try my best in resolving the issue.
Visitor: Well, they are known. At least 5 users emailed to your support and received responces saying the above-mentioned (no known issues to Samsung)
Victoria: I apologize for the inconvenience.
Victoria: Could I ask you a few questions to help me assist you further?
Visitor: if you are saying that there are no issues of its kind known to Samsung and no immediate fix/resolution is coming, I would have no other choice but to return the phone.
Visitor: please do
Victoria: Thank you.
Victoria: May I know since when are you experiencing this issue?
Visitor: ?
Visitor: time of day?
Victoria: I'm sorry, I'm referring to the time frame you are experiencing the issue.
Visitor: oh, this is my 2 nd phone (Skyrocket. I picked it up on Saturday
Victoria: Did you download any third party software or application?
Visitor: nope.
Victoria: Are you able to pair the phone with other Bluetooth devices?
Visitor: as i told you in the beginnin of conversation, please review it.....
Victoria: I'm sorry, I would like to confirm, whether you are able to pair the phone with other phones.
Visitor: yes, I am able to pair
Victoria: Your phone features the protocol of pairing to car devices to access calls.
Visitor: ok
Victoria: I suggest you delete the pairing on the phone, re-pair and try connecting the phone and check.
Visitor: i did multiple times and on multiple devices.
Victoria: I recommend you perform the soft reset to troubleshoot the issue that you are facing with the device. This might fix the issue.
Victoria: 1. Turn off the handset.
Victoria: 2. Remove the battery and wait for 30 seconds.
Victoria: 3. Reinsert the battery and turn ON the device.
Visitor: that's what I said in the begining of conversation...
Visitor: i did do that, it helps for a SINGLE connection.
Victoria: At this point of time, I request you perform a Hard reset that might fix the issue.
Victoria: If you perform hard reset on the device, the data will be deleted from the phone as a result of this procedure. This process does NOT delete data stored on the microSD card.
Victoria: Shall I provide the procedure to perform a Hard reset?
Visitor: i did that as well
Victoria: I sincerely apologize for the inconvenience.
Victoria: Please allow me to check and provide the right information.
Visitor: i would like you to to take the report so this becomes "known" issue. Also, please forward those links to your superiors, as those forums vividly describe the issue at hand.
Victoria: I'm sorry. I will definitely forward your feedback to the concerned department on your behalf.
Visitor: thanks.
Victoria: However, as you are referring that the issue still persists even after performing a Hard reset, I request you contact our Samsung Voice Support to file a service request in order to examine the device.
Visitor: ok
Victoria: You can contact our dedicated Galaxy S phones voice support team at 1-877-EZ2GALAXY (1-877-392-4252).They are available 24/7.
