From Acura HandsFreeLink:
Special instructions for pairing Samsung Phones (not all may be applicable to every phone)
SAMSUNG
Bluetooth Power
Ensure Bluetooth is turned ON permanently.
Discoverable/Visible
1. Go to Menu
2. Select Settings and/or Tools
3. Select Bluetooth
4. Select Settings/Visibility
5. Set Discovery Mode/Visibility to ON
Authorize Connection
1. Go to Menu
3. Select Bluetooth
4. Select HFL
5. Set Options to Authorize Device
Auto Answer
1. Go to Menu
3. Select Call Settings
4. Select Auto Answer or Answer Options
5. Set Auto Answer to OFF
Answer Options
1. Go to Menu
3. Select Call Settings (on some models, select Others, then Call Setup or Phone Settings, then Extra Settings)
4. Under Answer Options/Call Answer, select Flip/Slide, AnyKey, Send, or Auto Answer (if available).
Auto Answer is the preferred setting but any of these will work.
Setting discoverable to ON permanently makes a huge difference with a lot of phones, in my experience with the Acura HFL system.
