1. ramraj07's Avatar
    Just got the penny skyrocket on amazon, amazing phone!
    But for the battery. Been two days now, had a fully charged battery 8h before and after 20min of screen use and 20 min of talking (+1.5 hr of nonWIFI roaming, no data usage) its already at 40%. Maybe the iphone 4 has spoiled me but it looks like I can't get through an entire day at this rate! So I have some queries:
    1. Does anyone have a working 4g toggle option for skyrocket
    2. If I get a replacement battery, can I get a standalone charger or do I have to put it in the phone to charge it?
    3. If I charge a replacement battery and leave it in my bag, how many days before it completely loses the charge?
    4. I guess I will eventually go to CM, but will that change my battery woes to better/worse?
    Thanks for your help in advance!
    11-26-2011 04:21 PM
  2. 3lectroid's Avatar
    I noticed the first couple days of use on mine the battery life was terrible.. Its gotten a lot better now, can go a day and a half on moderate use..
    11-26-2011 05:35 PM
  3. Sedn's Avatar
    I agree with the above comment. I was almost about to trade it in for the original which had decent battery of the jump. Now my SR lives between 9 - 12 hours easily.
    11-26-2011 06:46 PM
  4. clindsey's Avatar
    Yes it gets better. I just got 1day 13hrs moderate use before putting it on the charger at 23%. I average between 12-18hrs with heavy use.
    As far as spare battery and charger - I use this: Samsung (OEM) Spare Battery Charging System for Samsung Galaxy S II SGH-T989
    It's for the T-Mobile GSII but works perfectly fine with the skyrocket...I always have a fresh battery
    The replacement battery fully charged will last weeks probably months with little if any discharge.
    11-26-2011 07:02 PM
  5. Aquarium1's Avatar
    I got a widget called Data Enabler from the android market. I don't know if you want that or if you're looking for an LTE enabler, which doesn't exist yet to my knowledge.
    The battery does get better with time.
    Sent from my SAMSUNG-SGH-I727 using Tapatalk
    11-26-2011 07:10 PM
