1. harryg27's Avatar
    Ever since I got the Commuter yesterday, people I've talked to have mentioned their voices echoing. Everything on my end sounds clear. I searched a little bit and found people have the same issues, but none I've seen have complained about the Skyrocket so far. I'm thinking about returning my case, but I'm curious if I'll have the same problem no matter what case I use. Any suggestions?
    03-30-2012 10:38 PM
  2. PBX-Tech's Avatar
    Have you tried turning on "Noise suppression"?
    Menu/Settings/Call/Additional settings
    I was having a voice drop out issue and this worked for me. I also have an Otter Box.
    03-31-2012 12:00 AM
  3. harryg27's Avatar
    Actually, noise suppression was on by default and turning it off has helped stop the echoing. I'm gonna continue that for a while and see how it does.
    03-31-2012 04:19 AM
  4. harryg27's Avatar
    Well I just got off the phone and the echoing had started again. Noise suppression is still turned off. First time since 3/30. Is it possible that low battery has something to do with it? It was around 30% while talking. I'm wondering if I should try the Impact Otter Box or another brand, such as the Case Mate Tough.
    04-05-2012 01:04 AM
  5. harryg27's Avatar
    Alright, it's been a month since my last post in this thread and I'm starting to get discouraged. My girlfriend mentioned the echoing problem again, which has been going on for the past two days. I haven't had this phone two months and I almost feel like giving up on it, especially after reading everything about the One X and SG3. I really do love the Skyrocket, it's just voice calls are aggravating. I shouldn't have to take the case off every time to be able to talk on the phone. I don't know what to do...
    05-06-2012 12:23 AM
  6. kberry66's Avatar
    my husband just switched to the skyrocket and went out of town. Every time I talk to him I hear this horrible echo. We turned off tons of stuff and finally I had him call at&t. Apparently this has been an issue with the speaker on the skyrocket and the only fix is to exchange the phone.
    05-23-2012 08:27 PM
  7. hdjdjficjdbdn's Avatar
    08-08-2014 07:13 AM
  8. hdjdjficjdbdn's Avatar
    Isolate the bottom microphone from the case with a slice of earplug watch the galaxy note 3 echo fix on youtube worked for my galaxy s4
    08-08-2014 07:15 AM
  9. hdjdjficjdbdn's Avatar
    08-08-2014 07:16 AM
  10. hdjdjficjdbdn's Avatar
    Isolate the microphone with a piece of ear plug watch the galaxy note three fix on youtube it works
    08-08-2014 07:17 AM
  11. hdjdjficjdbdn's Avatar
    This prosess works on all galaxy phones i have a s4. The bottom mic is the problem isolation of this will stop otterbox echo
    08-08-2014 07:19 AM
