04-16-2012 08:23 PM
33 12
tools
  1. skyrocketeer's Avatar
    Someone else was saying the newest update fixed the bluetooth issue for them...
    04-13-2012 08:41 PM
  2. TgeekB's Avatar
    First full day on my new extended battery. Not broke in yet but at 35% after 10 hours of moderate use. If this thing breaks in to be even better I will be very satisfied.
    jedah likes this.
    04-14-2012 04:06 PM
  3. jedah's Avatar
    Good deal. My new battery is lasting much longer than the original.
    Now I'm trying to figure out voice commands over Bluetooth. I have a Blueant T1 so its all voice activated... worked with my iPhone perfectly, but tells me that my skyrocket doesn't have "this feature" wtf? Feature... its been standard on every other phone for years!
    Are you using the included voice search for Android? I wasn't able to get this to work either w/ my bluetooth headset. Vlingo worked for me, though.
    04-14-2012 06:21 PM
  4. skyrocketeer's Avatar
    Voice search is unbelievably bad...me..."call Les"...android..."Call Las Vegas"...no no not Las Vegas..."call Les"...android..."call Las Vegas"...oh F_ _ _ it...
    04-14-2012 07:43 PM
  5. skyrocketeer's Avatar
    Hey man, sounds good! Can you post your screen on time for me? Just wondering if this thing is worth sporting for...sounds like it is.
    04-14-2012 08:21 PM
  6. TgeekB's Avatar
    I have actually been pleasantly surprised at the accuracy though, I have to admit, I don't use use it very often.
    04-15-2012 06:35 AM
  7. TgeekB's Avatar
    I'll try to do that later today.
    04-15-2012 06:38 AM
  8. Mharka13's Avatar
    One factor that drains battery is coverage. ATT doesn't have much cellular coverage in nj ny area. My battery drain faster than I can turn my phone off. But with half to full bars of connection I am at 36% after 16 hours and with "normal" daily use. As a matter of fact my skyrocket has better battery than my iphone did.
    04-16-2012 08:23 PM
33 12
